Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: ver 5.7 on Linux "Can't create graphics environment" |
| Print at Sep 29, 2026, 10:17:00 AM | View all posts in this thread on one page |
| Posted by richardlyons at Feb 2, 2018, 4:45:03 PM |
ver 5.7 on Linux "Can't create graphics environment" Installed 5.7 from the tgz 'SweetHome3D-5.7-linux-x64.tgz' and happily the program opens via 'SweetHome3D-Java3D-1_5_2', and runs 2D layout. However there is no 3D rendering, and the following errors are logged on startup It is a generic AMD 64-bit box running Arch Linux. (The distro packaged version is only ver 5.6, and in any case does not run.) Is this sufficient info to identify the problem? TIA |
| Posted by Puybaret at Feb 2, 2018, 7:58:08 PM |
Re: ver 5.7 on Linux "Can't create graphics environment" And how works SweetHome3D script? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by richardlyons at Feb 2, 2018, 8:48:03 PM |
Re: ver 5.7 on Linux "Can't create graphics environment" @Puybaret: The Sweethome3D script opens only the splash screen and stops (as before, with 5.6). |
| Posted by richardlyons at Feb 2, 2018, 9:56:25 PM |
Re: ver 5.7 on Linux "Can't create graphics environment" SOLVED!: I have just discovered the problem is caused by the fact I use a tiling window manager. Switching to icewm, for example, I get full 3D functionality. |
| Posted by yatsek at Apr 9, 2021, 6:08:24 PM |
Re: ver 5.7 on Linux "Can't create graphics environment" This post shows on top of Google search when looking for mentioned error - i.e: $ sweethome3dThis was not solved neither by using freshly downloaded version of SweetHome3D nor by running ./SweetHome3D-Java3D-1_5_2But what was VERY helpful was (found on some other place in this forum) to add: -Dcom.eteks.sweethome3d.j3d.useOffScreen3DView=truein script SweetHome3D |
| Posted by Gianca_UY at Aug 24, 2022, 4:54:54 AM |
Re: ver 5.7 on Linux "Can't create graphics environment" This post shows on top of Google search when looking for mentioned error - i.e: $ sweethome3dThis was not solved neither by using freshly downloaded version of SweetHome3D nor by running ./SweetHome3D-Java3D-1_5_2But what was VERY helpful was (found on some other place in this forum) to add: -Dcom.eteks.sweethome3d.j3d.useOffScreen3DView=truein script SweetHome3D I've just registered to thank yatsek because this worked (on v6.6.2 just in case)!! -Dcom.eteks.sweethome3d.j3d.useOffScreen3DView=true |
Current timezone is GMT Sep 29, 2026, 10:17:00 AM |
