Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: How to create wall & floor tiles with different grout thickness |
| Print at Oct 9, 2026, 9:52:14 AM | |
| Posted by peterweaver at Jan 22, 2018, 10:24:11 PM |
How to create wall & floor tiles with different grout thickness Hi there, Could you let me know, if is it possible to create a wall and a floor tiles with any decor etc? Cheers |
| Posted by okh at Jan 22, 2018, 10:39:30 PM |
Re: How to create wall & floor tiles with different grout thickness Yes. It all depends on the texture file you use. For a simple tiled wall, you can use one .png/.gif/.jpg of (64×64 is usually a good size). Add the grout as a border on your image, just as thick as you like. In the examples you got before, you will see multiple tiles (just to create an illusion of the tiles not being exactly the same). But one tile is usually enough. ok |
| Posted by peterweaver at Jan 22, 2018, 11:09:37 PM |
Re: How to create wall & floor tiles with different grout thickness Thanks for your reply. For example-if I want to create a tile 300mmx300mm and a grout 3mm.How can I do it step by step?Also I would like to use my own texture?Is it any online/youtube video? Thanks for your help |
| Posted by okh at Jan 22, 2018, 11:37:36 PM |
Re: How to create wall & floor tiles with different grout thickness Put a test tile in SF 346. You need a very simple file with border, scaled to 300×300. But to get it right, you need may to edit, create a larger tile pattern with some sort of graphics editor to get what you want. One approach, step by step, is the link to the manual I posted earlier: How to create personalized textures for Sweet Home 3D (PDF) by Ouais, translated by Hansmex. Not my preferred way, but it is a good start to get what you want. Check the other examples in SF 346 to see how it can work. ok tile_test.sh3d |
| Posted by peterweaver at Jan 23, 2018, 12:20:58 AM |
Re: How to create wall & floor tiles with different grout thickness Thanks a lot. I need to learn your instructions. I see how it goes. Regards |
| Posted by peterweaver at Jan 25, 2018, 12:31:21 AM |
Re: How to create wall & floor tiles with different grout thickness Are there any other ideas to make a tiles?I have been trying to use your attachment and I can not. |
| Posted by bdfd at Jan 27, 2018, 6:59:58 AM |
Re: How to create wall & floor tiles with different grout thicknessAre there any other ideas to make a tiles?I have been trying to use your attachment and I can not. Hi, You can take a thin box with its texture to apply it on a wall. The advantage is the choiced size. There is an example HERE the credance over the sik (last picture on thread "Cubic houses - part 2"). Regards. ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by peterweaver at Jan 30, 2018, 10:06:17 PM |
Re: How to create wall & floor tiles with different grout thickness Hi, Thanks for your reply. I have seen your cubic houses. Where can I download those kitchen cabinets/drawer,furniture etc? Cheers. Regards |
| Posted by bdfd at Jan 31, 2018, 12:59:34 PM |
Re: How to create wall & floor tiles with different grout thickness Hi, All furnitures are standard in sh3d. see category named 'kitchen'. ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
Current timezone is GMT Oct 9, 2026, 9:52:14 AM |
