Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Recalculate floor |
| Print at Sep 6, 2026, 3:37:24 AM | View all posts in this thread on one page |
| Posted by qythyx at Jan 6, 2018, 8:14:22 AM |
Recalculate floor It would be great if there was a feature to recalculate the layout of a floor, taking into account doors and such. The issue I have is that I create a set of walls defining a room and add doors to the room. Then I fill in the floor area, which automatically calculates small indents for those doors. Then I sometimes change a door. After which I need to delete and recreate the floor, which is annoying. It would be great if there was an option to just recalculate the existing floor layout. Thanks! |
| Posted by VeroniQ at Jan 6, 2018, 10:17:30 AM |
Re: Recalculate floor If you double-click in a room (surrounded by walls), it recalculates automatically the layout of the floor. See this User Guide chapter. Don't forget to delete the last floor layout before. |
| Posted by Puybaret at Jan 6, 2018, 10:53:20 AM |
Re: Recalculate floor VéroniQ, if you double click in a space surrounded by walls, it creates a new room and doesn’t recalculate the existing room if any. But if you cut an existing room, create a new one at the same place with a double click, then select Edit > Paste style menu item, it will perform the update you look for. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Sep 24, 2023, 5:15:50 PM |
Re: Recalculate floor Qythyx, try the Recalculate room points item which was added to plan contextual menu in version 7.2. You have to select a room and right click at a point where the room points should be recalculated to get this menu item. If the points don't need to be recalculated, the menu item won't appear. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 3:37:24 AM |
