Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Version 5.6 Solution (Windows 10) |
| Print at Aug 12, 2026, 3:56:02 AM | |
| Posted by [email protected] at Jan 4, 2018, 8:20:37 PM |
Version 5.6 Solution (Windows 10) I had a problem with version 5.6 using Windows 10 64 bit with error message "DirectX/OpenGL". I installed dxwebsetup.exe, JavaSetup8u151.exe and SweetHome3D-5.6-windows.exe. The problem was solved. I am using HP Pro-book 650 G1, I was running Windows 7 32 bit then upgraded to Windows 10 64 bit and the problem started but now it is solved. ![]() |
| Posted by Puybaret at Jan 5, 2018, 9:49:28 AM |
Re: Version 5.6 Solution (Windows 10) Great! Thanks for your feedback ![]() As Sweet Home 3D comes with its own copy of Java, I wonder if installing JavaSetup8u151.exe is really required. And what is dxwebsetup.exe? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by [email protected] at Jan 5, 2018, 10:33:03 AM |
Re: Version 5.6 Solution (Windows 10) dxwebsetup.exe it is a DirectX Web Setup file, it checks if your system is up to date with DirectX. |
Current timezone is GMT Aug 12, 2026, 3:56:02 AM |
