Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Search luminous neon objects! |
| Print at Aug 26, 2026, 6:21:22 AM |
| Posted by alaX at Jan 13, 2018, 7:02:52 PM |
Re: Search luminous neon objects!![]() Neon digits orange |
| Posted by rontant at Jul 28, 2018, 5:09:32 AM |
Re: Search luminous neon objects! Oh man! I have been searching high and low for weeks to make a glowing material and only now I stumbled upon this thread. I think thhis should be made sticky or at least mentioned in the Tips section. This is very useful. Not only for those who want to make neon signs. Below is the example how I made my spotlight housing rim to glow using tips found on this thread. See the spotlight on the right? |
| Posted by enkonyito at Mar 10, 2020, 4:00:06 AM |
Re: Search luminous neon objects! With the YafaRay rendering engine, you can transform any object into light. Based on the logos and neon signs created by Ceciliabr. ---------------------------------------- EnkoNyito |
| Posted by Mike53 at Jan 27, 2021, 5:50:42 PM |
Re: Search luminous neon objects! Hi, trying, unsuccessfully, to get a stair tread to glow .Is it only the illum line that has to change, or is there something in the .obj file as well. Tried with Path instead of ambient occlusion, just took longer to get the same result. Any help would be appreciated. Thx Mike |
| Posted by Puybaret at Jan 27, 2021, 7:27:12 PM |
Re: Search luminous neon objects! Sorry Mike, it won't work with transparent materials. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Mike53 at Jan 27, 2021, 7:37:22 PM |
Re: Search luminous neon objects! Ok mate, thx for the prompt reply, even if you are the bearer of bad news, you may keep your head. ![]() |
| Posted by Mike53 at Feb 5, 2021, 9:18:05 AM |
Re: Search luminous neon objects! So this is what i came up with to get a similar effect ![]() created a rectangle of walls, 2 mm x 30 mm exported it and modified its MTL |
| Posted by DeonEva at Mar 3, 2021, 5:59:02 PM |
Re: Search luminous neon objects! Thanks everyone for the tips and helpful links! there are one in a million. All kinds of signs, letters, and so on! Hurrah!! ---------------------------------------- "Let the beauty of what you love be what you do." https://www.worktime.com/employee-monitoring |
| Posted by lemaj77 at Sep 15, 2022, 1:31:23 PM |
Re: Search luminous neon objects!First of all thank you for everything you do for us on sweet home 3d. please are there only capital letters? can we also have the alphabet in lowercase letters? can the font be changed? thank you |
| Posted by enkonyito at Feb 12, 2023, 2:58:45 PM |
Re: Search luminous neon objects! Libraries of light shapes based on neon lights and fluorescent logos created by Ceciliabr. Available in the Lights category with the "neon" or "logo" keywords and compatible with SweetHome3D-7.0. ---------------------------------------- EnkoNyito |
Current timezone is GMT Aug 26, 2026, 6:21:22 AM |
