Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Artifacts in 3D view under certain view angles |
| Print at Aug 15, 2026, 2:48:42 PM | |
| Posted by harryth at Dec 17, 2017, 1:18:51 PM |
Artifacts in 3D view under certain view angles Hello, this is my first thread in this forum. First of all huge compliments for the makers of this very good 3D design tool. I like it very much and it helps a lot to come closer to the perfect home I have encountered an issue which I cannot find a solution for: My house has 3 niveaus: basement, 1'st floor and a roof. The roof I have constructed using 2 walls exported as OBJ and reimported as furniture. This worked as expected. But in the standard 3D view as well in photo mode there is a visible artifact which seems to be related to the roof. ![]() if I change the viewing angle, the artifact disappears Any idea, how I can get arround this issue? Thanks in Advance Best Regards Harald |
| Posted by okh at Dec 17, 2017, 11:13:20 PM |
Re: Artifacts in 3D view under certain view angles When exporting,select and export selection only. What you see is a rogue floor. Visible from only one side. ok |
| Posted by harryth at Dec 18, 2017, 8:36:17 AM |
Re: Artifacts in 3D view under certain view angles Thanks a lot, this was the missing info. Best Regards Harald |
Current timezone is GMT Aug 15, 2026, 2:48:42 PM |
