Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Online (Java Web Start) not working. |
| Print at Oct 1, 2026, 7:10:17 AM | View all posts in this thread on one page |
| Posted by mumon66 at Oct 30, 2017, 6:58:37 PM |
Online (Java Web Start) not working.Hi, I'm trying to use the Online version of SH3D; but I'm unable to make it work. When I click on "Launch Sweet Home 3D with Java Web Start" in http://www.sweethome3d.com/download.jsp, I see the splash window, then the "downloading", and I get a security confirmation dialog; after confirming, nothing happens. I've tried to run Java Web Start in a console, like this: javaws "http://www.sweethome3d.com/SweetHome3D.jnlp" I get these messages from Java: It sits there and stays. I cannot understand what's the base problem; it's clear that the applet wants to run /usr/bin/xprop but it cannot; is it that the issue? I'm using Ubuntu 17.04 with IcedTea 1.6.2-3.1ubuntu3. |
| Posted by Puybaret at Oct 31, 2017, 6:20:03 PM |
Re: Online (Java Web Start) not working. Java Web Start version and Online applet are two different parts of Sweet Home 3D, but from your description, I guess its the Java Web Start version you tried. From the error, you may not have the rights to run xprop. Check its rights and grant yourself the right to run it with a command looking like: su chmod +x /usr/bin/xprop---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mumon66 at Nov 6, 2017, 1:17:20 PM |
Re: Online (Java Web Start) not working.You're right, Java Web Start and not Online. Permissions on xprop are already set: $ ls -la /usr/bin/xprop -rwxr-xr-x 1 root root 37912 May 6 2015 /usr/bin/xprop Mysterious, but that's not the issue: I have tested javaws the same under Arch Linux, where there's no /usr/bin/xprop; "cannot access" is thrown, but then everything works OK. I've gone a bit further by launching: javaws -noupdate -verbose -jnlp "http://www.sweethome3d.com/SweetHome3D.jnlp" After a couple of minutes and tons of messages, I get this messages: Then, nothing more happens, although javaws doesn't end. So, it opens a listener on localhost port 46523 (yes, I have a cntlm running on port 3128 and no, enabling direct connection has no effect), but then... what's happening? I hate Java... ![]() |
| Posted by Puybaret at Nov 6, 2017, 1:42:11 PM |
Re: Online (Java Web Start) not working. Don't hate Java otherwise Sweet Home 3D would have never existed, moreover under Linux ![]() But why not trying another solution available at download page? You could try the installer or the Jar executable version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mumon66 at Nov 6, 2017, 3:38:27 PM |
Re: Online (Java Web Start) not working. Of course, I'm joking... That's only to curse a bit the ones who invented Java logging system, making it both way too verbose and hard to debug... ![]() I already use the installer version, and it works (thanks!); the problem is I've installed the one packaged from maintainers. There's a several days delay from a new version is out to it's updated by maintainer - and I couldn't wait to see the new "punch-through windows" feature. What's worse is that the different Linux distributions I use don't upgrade versions in sync; so I happened to open a file with and older version of SH3D, and I feared to break it. Moreover, I'd like to share .sh3d files with Linux users, without forcing them to install the package. |
| Posted by Puybaret at Nov 8, 2017, 10:47:11 AM |
Re: Online (Java Web Start) not working. Believe it or not, the stack traces that appears in logs are a great invention. They save a lot of time in debugging. the problem is I've installed the one packaged from maintainers Please use an installer provided at download page.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 1, 2026, 7:10:17 AM |
