Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Doesn't launch anymore in Ubuntu 17.10 |
| Print at Oct 1, 2026, 7:10:38 AM |
| Posted by Golia at Jul 28, 2018, 7:16:06 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 it only happens to me that it does not work FurnitureLibraryEditor? |
| Posted by UbuntuBirdy at Jul 28, 2018, 8:13:20 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Not only to you. I can start it and I can load a library, but I'm not able to do something else... If I execute any of the other functions nothing will happen. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by UbuntuBirdy at Feb 12, 2019, 11:26:50 AM |
Re: Doesn't launch anymore in Ubuntu 17.10 Since last week an extensive update for OpenGL was released, I can start SH3D again with the standard script (SweetHome3D; SweetHome3D-Java3D-1_5_2 is not longer needed), so Java3D runs on Ubuntu now also in version 1.6. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by hansmex at Feb 12, 2019, 12:43:55 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Congratulations UB! I'm jealous you can use SH3D out of the box. On my system nothing happens :-( H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by UbuntuBirdy at Feb 12, 2019, 1:04:44 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Hans, try the follwoing command in your terminal: glxinfo | grep 'version' Which version of OpenGL does this indicate? ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by hansmex at Feb 12, 2019, 2:03:03 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 And the answer is.... server glx version string: 1.4Problem is: SH3D doesn't do anything at all with either script. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by UbuntuBirdy at Feb 12, 2019, 2:31:48 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Hans, you still have to start SH3D via the starter we created. But no longer linking to the 1.5.2 script but to the SweetHome3D script. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by hansmex at Feb 12, 2019, 3:27:47 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Thank you very much, UB, will give it a try! ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by UbuntuBirdy at Feb 13, 2019, 10:01:48 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 After allmost 200h of developing parts, 3D-printing them, figure out if they work, redesign and reprint them (during the last 6 days...) I had now some time left to test FLE and as expected it now works like a dream - thanks to OpenGL 4.5 and higher! ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by UbuntuBirdy at Feb 14, 2019, 7:00:20 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Hans, if it still does not work for you, do not bother too much, because the performance of java3d1.6 is much worse than java3d1.5.2... ...wondering why... ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
Current timezone is GMT Oct 1, 2026, 7:10:38 AM |
