Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: orientation of walls |
| Print at Aug 22, 2026, 3:47:01 AM | View all posts in this thread on one page |
| Posted by ChrisPapp at Oct 14, 2017, 10:43:40 AM |
orientation of walls Dears, we downloaded Sweet Home 3D for a project a few days ago. It's a great tool and quite easy and focussed for our demand. Only 1 thing, where I do not find a solution: Is it possibe to fix a wall with a certain thickness at and then set thickness? Let's say a 3m long vertical wall starts at (0,0) with a thickness of 30, then currently the left ends at (-15,300) and the right side at (15,300). The issue with this in a complex drawing with different wall sizes the measurements are quite complicated if you mix draw from a drawing and measure. You allways need to consider wall thickness in the drawings. Is there a possibility to fix the wall orientation not to the middle of the wall but to an edge? Thx Chris |
| Posted by hansmex at Oct 14, 2017, 8:27:42 PM |
Re: orientation of walls No, walls are always drawn with the coordinates defining the middle of start and end point ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Aug 22, 2026, 3:47:01 AM |
