Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Same image – like night & day - a miracle? |
| Print at Sep 20, 2026, 11:25:02 AM |
| Posted by enkonyito at Jan 10, 2018, 4:42:43 AM |
Re: Same image – like night & day - a miracle? @Ceciliabr I think I prefer dark level 2. The difference might seem minimal on these small pictures, but will probably be a lot more visible on a larger image. By default, the dark value is 0.You can test the minimum night brightness (dark value 1/255) with the beta version of the plug-in . [If it's possible, I'll try to embed a dark level test instead of changing the value in the source code.] On the two lower images I can see there is a blue hue that is more visible on dark level 1 than on dark level 2, but it seems to be the other way around on the two bathroom images. Does this have anything to do with sky texture or colour? As the SimpleRoom.sh3d project has an outside opening, I used a black texture for the sky.---------------------------------------- EnkoNyito |
| Posted by Ceciliabr at Jan 11, 2018, 10:10:05 AM |
Re: Same image – like night & day - a miracle? You can test the minimum night brightness (dark value 1/255) with the beta version of the plug-in . I did, but I did not notice any difference from the default renderer. cec |
| Posted by enkonyito at Jan 11, 2018, 7:30:01 PM |
Re: Same image – like night & day - a miracle? I did, but I did not notice any difference from the default renderer. With your project, the difference between dark value = 0 (default renderer) and dark value = 1 is not obvious. That's why I added dark value = 2. The PVR-1.4_betaTest version will allow you to choose the desired dark level (0, 1 or 2). ![]() Enko ---------------------------------------- EnkoNyito |
| Posted by Ceciliabr at Jan 12, 2018, 6:09:54 PM |
Re: Same image – like night & day - a miracle? Perfect! ![]() With dark level 2 I can see the body of the bathtub. This bathroom has no windows. I will make a window and do another test after dinner :) I think adjustable DARK LEVEL is a keeper. cec |
| Posted by Ceciliabr at Jan 12, 2018, 9:45:56 PM |
Re: Same image – like night & day - a miracle? Bathroom with window. cec |
| Posted by enkonyito at Jan 13, 2018, 5:50:24 PM |
Re: Same image – like night & day - a miracle? The option can also be used for the exterior. I think I will also choose dark level 2 for the final version of the plug-in. ---------------------------------------- EnkoNyito |
| Posted by VeroniQ at Jan 13, 2018, 8:40:57 PM |
Re: Same image – like night & day - a miracle? I like dark level 2 renderings! Thank you EnkoNyito. |
Current timezone is GMT Sep 20, 2026, 11:25:02 AM |
