Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: no texture on surface |
| Print at Sep 21, 2026, 4:47:13 AM | View all posts in this thread on one page |
| Posted by bizusomoy at Sep 22, 2017, 9:07:09 AM |
no texture on surface hi, my problem is, after applying texture on furniture when I give final render it shows the only color on the surface but not a texture.what I will do.plz help me. |
| Posted by bdfd at Sep 22, 2017, 9:39:21 AM |
Re: no texture on surface hi, my problem is, after applying texture on furniture when I give final render it shows the only color on the surface but not a texture.what I will do.plz help me. Hi,Can you show us (screenshots) a picture before and after ? What are the parameters of rendering ? What is the size of the texture (in pixels) ? ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by hansmex at Sep 22, 2017, 9:56:38 AM |
Re: no texture on surface Probably a model from the Sketchup Warehouse. Sh*t happens with those. ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by okh at Sep 22, 2017, 11:15:21 AM |
Re: no texture on surface Probably a model from the Sketchup... Yes, most likely. Around the forum there are several threads about textures and Sketchup. It is usually possible to fix with Sketchup - making sure that textures/colours only are applied to the outer surfaces (using "Orient faces", "Reverse faces" and avoid and remove the "Two sided faces"). But on a complicated model, that can be a cumbersome process.In recent versions of SH3D, it is sometimes possible to remove the back surfaces that bleed through and ruin the rendering: If the offending material is listed in the material list (and not used elsewhere) it can be set to invisible. But then you need to be lucky with the model. ok |
| Posted by bizusomoy at Sep 22, 2017, 12:31:58 PM |
Re: no texture on surface https://www.facebook.com/photo.php?fbid=10214...51&type=3&theater here in this link, you can see the floor there is no texture but only color.I also use texture on the walls but there is also the same problem. |
| Posted by Puybaret at Sep 22, 2017, 12:46:22 PM |
Re: no texture on surface What version do you use (see About dialog box)? Would you have duplicated walls and rooms (possibly introduced after a quick copy paste), with a version of these objects textured differently? Just temporarily delete one of them to check that. If this is not the right idea, could you share or send me a simplified version showing the bug? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by bizusomoy at Sep 22, 2017, 1:25:32 PM |
Re: no texture on surface I m using 5.5 version.I did but there are the same thing happening, |
| Posted by Puybaret at Sep 22, 2017, 1:50:35 PM |
Re: no texture on surface So please, share or send me a simplified version showing the bug? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by qythyx at Sep 25, 2017, 10:39:12 AM |
Re: no texture on surface I sometimes see something similar. It happens when I'm rendering a video, or even just single images multiple times (different view points, etc). Sometimes the texture is fine, but sometimes it's just grey. Do others see this? Any ideas? |
Current timezone is GMT Sep 21, 2026, 4:47:13 AM |
