Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Existing and Proposed Condistions |
| Print at Sep 6, 2026, 3:47:39 AM | |
| Posted by tomhf at Sep 19, 2017, 4:29:52 PM |
Existing and Proposed Condistions I am doing a plan for remodeling a second floor and adding a bathroom. Is there a way to distinguish between existing and proposed features on the plan to show what is being removed and what is new on a single plan sheet. Typically the existing conditions would be shown as lighter and walls to be removed can be identified. Not sure how to do that with this program. |
| Posted by Puybaret at Sep 20, 2017, 8:05:38 AM |
Re: Existing and Proposed Condistions I would suggest to use three levels at the same elevation : - one where you draw everything in common (walls, rooms and furniture that won't change) - one where you draw things you want to remove or move - a last level where you draw new things. Then you can make viewable either two last levels to view the differences. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 3:47:39 AM |
