Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: measurement between walls |
| Print at Sep 26, 2026, 9:12:46 PM | View all posts in this thread on one page |
| Posted by michaelbr at Sep 2, 2017, 2:44:10 PM |
measurement between walls Just found this amazing apps, installed and learning. Not sure if I'm not doing it right or this feature is not there, what I want to do is to measure the distance between two walls, the trouble is whenever I moved a wall, the distance (in the menu bar, there's an icon for distance, that's the one I used). I tried to click the mouse when the blue line at the wall showed up, but if I moved the wall, the measurement remains in the same place, did not move with the wall. Is it possible to make the distance move along the wall? If so how? ---------------------------------------- Thanks for your comment/suggestion Michael |
| Posted by okh at Sep 3, 2017, 11:47:22 AM |
Re: measurement between walls Select both measurement and wall with SHIFT-Select before you move. Or delete first measurement, and double-click with measurement tool on the wall in its new location. ok |
Current timezone is GMT Sep 26, 2026, 9:12:46 PM |
