Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: How to know what measurements to set on imported floorplan with no scale present |
| Print at Jul 22, 2026, 10:21:14 AM |
| Posted by sorrow at Aug 6, 2017, 9:43:24 AM |
How to know what measurements to set on imported floorplan with no scale present Hi all, I am importing a floorplan with no scales present so that I can draw it out on Sweethome 3D, just to check how should i go about setting the dimensions as the system prompts me to insert a measurement before i can click continue. Many thanks in advance. |
| Posted by hansmex at Aug 6, 2017, 10:40:12 AM |
Re: How to know what measurements to set on imported floorplan with no scale present Make a guess... Sometimes beds are drawn in bedrooms, take those as a guideline and set them as 200 or 210 cm in length. Kitchen sinks are usually around 60 cms deep, you could take those. It's not perfect, but better than nothing. Use the zoom function to enlarge your background image. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by sorrow at Aug 6, 2017, 10:47:05 AM |
Re: How to know what measurements to set on imported floorplan with no scale present Make a guess... Sometimes beds are drawn in bedrooms, take those as a guideline and set them as 200 or 210 cm in length. Kitchen sinks are usually around 60 cms deep, you could take those. It's not perfect, but better than nothing. Use the zoom function to enlarge your background image. H Hi Hansmex, thanks for your advice, so meaning i have to make a wild guess as nothing that allows an auto gauge even if i have the total area in sqft. ![]() |
| Posted by hansmex at Aug 6, 2017, 11:36:22 AM |
Re: How to know what measurements to set on imported floorplan with no scale present If you have the total area, you can make a first guess. Make a room that equals your total area, and compare the room size with the given surface. Adjust scale according to need. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by okh at Aug 6, 2017, 12:00:59 PM |
Re: How to know what measurements to set on imported floorplan with no scale present ..take those as a guideline and set them as 200 or 210 cm in length... Or sometimes 190cm outside Holland/Scandinavia Hansmex' advice is good as there is usually some identifiable length somewhere in the drawing (pick the longest). Even a door/window could give an approximate result as long as the proportions are correct. ..a wild guess as nothing that allows an auto gauge even if i have the total area in sqft... Actually, if you have the area, you might be able to make an estimation of the length of one wall. After you have the approximation (I would not call it a wild guess). You can go back and adjust. Create a room in the drawing and see how well it matches the area you have. Then you can change the measurements in the background drawing. When you start drawing a couple of walls, often the lengths will become apparent as there are often some standard measurements in a plan. ok |
| Posted by sorrow at Aug 6, 2017, 4:04:36 PM |
Re: How to know what measurements to set on imported floorplan with no scale present ..take those as a guideline and set them as 200 or 210 cm in length... Or sometimes 190cm outside Holland/Scandinavia Hansmex' advice is good as there is usually some identifiable length somewhere in the drawing (pick the longest). Even a door/window could give an approximate result as long as the proportions are correct. ..a wild guess as nothing that allows an auto gauge even if i have the total area in sqft... Actually, if you have the area, you might be able to make an estimation of the length of one wall. After you have the approximation (I would not call it a wild guess). You can go back and adjust. Create a room in the drawing and see how well it matches the area you have. Then you can change the measurements in the background drawing. When you start drawing a couple of walls, often the lengths will become apparent as there are often some standard measurements in a plan. ok ![]() |
| Posted by okh at Aug 6, 2017, 6:01:09 PM |
Re: How to know what measurements to set on imported floorplan with no scale present ..let me see how I can upload the drawing on google drive or dropbox and see if anyone can guide a stupid me from there... I once asked a local fisherman that I could not understand how he could navigate his boat through an archipelago avoiding every numerous, unmarked, underwater rock. His answer was: "How do you think I found them?" Your question is not stupid, I only reply because I have wasted some time trying to figure it out ![]() |
| Posted by sorrow at Aug 7, 2017, 4:06:29 AM |
Re: How to know what measurements to set on imported floorplan with no scale present ..let me see how I can upload the drawing on google drive or dropbox and see if anyone can guide a stupid me from there... I once asked a local fisherman that I could not understand how he could navigate his boat through an archipelago avoiding every numerous, unmarked, underwater rock. His answer was: "How do you think I found them?" Your question is not stupid, I only reply because I have wasted some time trying to figure it out ![]() Thank you Okh, hope I didn't say anything wrong anyways as mentioned, I included a floorplan i wanted to draw in general, its a 1,066 sqft 3 bedders unit. Was wondering if someone could point me in the right direction with a visual image as I understand you and Hansmex was telling me some dimensions, so maybe a visual would be better to explain. Thank you all once again. https://www.dropbox.com/s/cufix2uuvfyeicc/Brooks%201066sqft.jpg?dl=0 |
| Posted by bdfd at Aug 7, 2017, 9:16:56 AM |
Re: How to know what measurements to set on imported floorplan with no scale present ... anyways as mentioned, I included a floorplan i wanted to draw in general, its a 1,066 sqft 3 bedders unit. Was wondering if someone could point me in the right direction with a visual image as I understand you and Hansmex was telling me some dimensions, so maybe a visual would be better to explain... Hi,![]() https://www.dropbox.com/s/cufix2uuvfyeicc/Brooks%201066sqft.jpg?dl=0 For me there is one unuseless bath : this bath3 far in the rear of the kitchen. If it possible for you, Near BR3, you delete it and you can grow up the BR3... ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by hansmex at Aug 7, 2017, 10:56:33 AM |
Re: How to know what measurements to set on imported floorplan with no scale present Try this file , took me al of 10 minutes. ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Jul 22, 2026, 10:21:14 AM |
