Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 5.5 |
| Print at Sep 14, 2026, 6:10:27 AM |
| Posted by Puybaret at Aug 4, 2017, 6:06:11 PM |
Re: Sweet Home 3D 5.5 The version 5.5 beta 10 (Java Web Start, Windows installer and Linux 64 installer) comes with an update of Hungarian translation and a new look for the Furniture modification dialog box with different labels for the rotation around the horizontal axes. ![]() Hope you'll find it clearer ![]() I propose also a second installer for Windows with the version 5.5 beta 11, to get your feedback about how Sweet Home 3D works with the latest Java Runtime Environment 1.8.0_144, one year later I decided to stuck on JRE 1.8.0_51 to fix the crash problems encountered by some of you (the installer of Sweet Home 3D version 5.5 beta 10 still comes JRE 1.8.0_51). To check if it works better, I hope some of you will have the patience to test whether Sweet Home 3D 5.2 still crashes, then try the new version 5.5 beta 11. Thanks for your tests ![]() If needed, the MD5 of SweetHome3D-5.5.beta10-linux-x64.tgz is da2f87dfd603909f9f3d38973ce6051b ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Aug 4, 2017, 6:42:53 PM |
Re: Sweet Home 3D 5.5 The Linux_64_installer links downloads a file called SweetHome3D-5.5.beta11-jre1.8.0_144-windows.exe. Is that correct? H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Aug 4, 2017, 7:28:28 PM |
Re: Sweet Home 3D 5.5 Sorry Hans, I fixed the link. Thanks for reporting the issue ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by bdfd at Aug 4, 2017, 8:38:33 PM |
Re: Sweet Home 3D 5.5 ...If needed, the MD5 of SweetHome3D-5.5.beta10-linux-x64.tgz is da2f87dfd603909f9f3d38973ce6051b Not chance !It's now the second link for linux which is bad... ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Puybaret at Aug 4, 2017, 9:18:26 PM |
Re: Sweet Home 3D 5.5 Fixed. Thank you. Bad luck ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by okh at Aug 7, 2017, 3:56:29 PM |
Re: Sweet Home 3D 5.5 Guess 'nothing to report' can also be a report Worked my way through the features and did some random editing, and Java Web Start seems to work beautifully under Win81. Thanks for the new features. ok |
| Posted by bdfd at Aug 8, 2017, 11:48:52 AM |
Re: Sweet Home 3D 5.5 Just a remark : Today, I use sh3d 5.5 beta11 in exe mode with success. I won in using jlnp method with a good '.bat' file. but i saw that the launched version was beta12 ! Is it the good ? ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by enkonyito at Aug 11, 2017, 10:14:02 PM |
Re: Sweet Home 3D 5.5 Is it possible for the camera to tilt along the Y axis like furniture? ---------------------------------------- EnkoNyito |
| Posted by Puybaret at Aug 12, 2017, 12:00:15 AM |
Re: Sweet Home 3D 5.5 Bdfd, I don't post a message at each update, moreover when it's about very small changes, but you're right, the current beta version is 12. Enkonyito, I wonder what your request could be useful for. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by enkonyito at Aug 15, 2017, 4:37:35 AM |
Re: Sweet Home 3D 5.5 Emmanuel, this "roll" option may not be very useful applied to the virtual visitor but in the case of a video rendering this would be an additional basic camera movement. ![]() ---------------------------------------- EnkoNyito |
Current timezone is GMT Sep 14, 2026, 6:10:27 AM |
