Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Using Dimensions in Name of object |
| Print at Sep 6, 2026, 4:24:59 AM | |
| Posted by yanuk at Jun 28, 2017, 6:54:38 AM |
Using Dimensions in Name of object It would be nice if there are some short codes we can use to put in the dimensions of an object (furniture) in the name so it will appear in the plan when we tick the check box. For example: - if the dimension of the object is Width: 100cm Depth: 50cm Height: 90cm. In the name field, if i can key in Table: %d x %w x %h Teak SH3D automatically displays Table: 50 x 100 x 90 Teak as the name of the object on the plan Some short codes can be %d - depth %w - width %h - height %x - location X %y - location Y %e - elevation %a - angle Hope the devs will consider this! Thanks in advance! |
Current timezone is GMT Sep 6, 2026, 4:24:59 AM |
