Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to edit a room |
| Print at Oct 15, 2026, 7:09:34 AM | |
| Posted by hoangtrunglien at Jun 25, 2017, 11:13:29 AM |
How to edit a room Hi, I have created a room and the size of it is now shown. How can I make the room larger or add another room to it? I do not know the keys I need. Dragging the edges does not leed to what I want. Thanks for your help. |
| Posted by bdfd at Jun 26, 2017, 8:00:36 AM |
Re: How to edit a room Hi, Try to cancel the 'magnetism' option to update the room, or Add new walls for new room... ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Puybaret at Jun 26, 2017, 11:20:03 AM |
Re: How to edit a room I guess you moved the walls, expecting the room points would follow but this is not how Sweet Home 3D works. Select the room surface and move the points to the new wall corners, and you'll see that magnetism will help you place them easily on the corners. You may also delete the room surface and create it again with the room creation tool. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 15, 2026, 7:09:34 AM |
