Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Furniture Library Editor - L4J Look and Feel fix needed |
| Print at Sep 6, 2026, 4:16:10 AM | View all posts in this thread on one page |
| Posted by Bubblobill at Jun 11, 2017, 6:21:46 PM |
Furniture Library Editor - L4J Look and Feel fix needed Hi folks, I am on Win 10 and have applied the L4J.ini fix for SH3D in order to have functional dialog boxes. Same problem exists in the Furniture Library Editor but I haven't managed to fix it with an ini file. Care to share the switches required to set the look and feel options in this too? Cheers, Jay |
| Posted by Puybaret at Jun 12, 2017, 8:06:20 PM |
Re: Furniture Library Editor - L4J Look and Feel fix needed A Launch4J ini file works only with exe generated with Launch4J, and the Furniture Library Editor is available only as a Jar executable. If you want to apply the tip proposed to fix Sweet Home 3D problems with file dialog under Windows 10, you should run the editor from the command line, with a command similar to: java -Dswing.defaultlaf=javax.swing.plaf.metal.MetalLookAndFeel -jar path\to\FurnitureLibraryEditor-1.20.jar---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Bubblobill at Jun 13, 2017, 5:29:37 PM |
Re: Furniture Library Editor - L4J Look and Feel fix needed No joy. Did not work for me. *sigh* |
| Posted by Puybaret at Jun 13, 2017, 11:22:54 PM |
Re: Furniture Library Editor - L4J Look and Feel fix needed Sorry, I should have tried on my side first. I updated the source code but this won't be available before the next version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 4:16:10 AM |
