Print at Sep 6, 2026, 4:23:32 AM View all posts in this thread on one page
Posted by paddifly at Jun 4, 2017, 9:37:00 PM
vertical rounded wall
Hello,is it possible to create a wall, which is left side rounded vertical by a specified radius?? thanks for any solution smile .
Ralf
Posted by hansmex at Jun 5, 2017, 6:46:58 AM
Re: vertical rounded wall
1st method
- insert an invisible, insertable cylinder
- doesn't work because the cylinder makes a square cut in the wall, not a rounded one
2nd method
- draw a wall that has the desired curvature
- export and import it, rotating it 90 degrees
- could work for a straight wall, but will cause problems in corners
3rd method
- use another program
Sorry
Posted by bdfd at Jun 5, 2017, 8:26:13 AM
@hans,
4th method
- Maybe with a hollow cylinder and adjusting walls, floor and ceiling ???
=> It will be not easy ! biggrin
