Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: 3D rendering - Where to change default settings |
| Print at Sep 20, 2026, 8:32:38 AM | View all posts in this thread on one page |
| Posted by jimass at May 31, 2017, 12:53:07 PM |
3D rendering - Where to change default settings Hi, can you send me path, where to find file with Photo create setting. So every time when I will be rendering 3d photo there will be my options. For example width 1680px height 1120px, Time 5.30pm etc. Thank you. |
| Posted by Puybaret at May 31, 2017, 10:11:11 PM |
Re: 3D rendering - Where to change default settings The default value of this parameters are directly set in the program : in HomeEnvironment class for photo width and height, and in Camera class for the time. So, if you know a little Java and how to build a program from its source code, you can change these settings with no problem, otherwise I fear it won't be possible. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by jimass at Jun 1, 2017, 1:01:38 PM |
Re: 3D rendering - Where to change default settings Thank you! I'm not very good in java but I changed size of photo and time to 17:30. Can you pls advice me how to change date from actuall date to for example 15 July. Also I need uncheck Aplly proportions and Add celing light. private static long midday() { Calendar midday = new GregorianCalendar(TimeZone.getTimeZone("UTC")); midday.set(Calendar.HOUR_OF_DAY, 17); midday.set(Calendar.MINUTE, 30); midday.set(Calendar.SECOND, 0); midday.set(Calendar.MILLISECOND, 0); return midday.getTimeInMillis(); Thank you very much. |
| Posted by jimass at Jun 7, 2017, 10:27:08 AM |
Re: 3D rendering - Where to change default settings Somebody can help me please? |
| Posted by Puybaret at Jun 7, 2017, 12:47:33 PM |
Re: 3D rendering - Where to change default settings I gave you the idea last time. Changing the date is about learning to use GregorianCalendar API and the other settings can be found in the code just by searching their name. Good luck! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 20, 2026, 8:32:38 AM |
