Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: cant not open, 'modify walls...' dialogue |
| Print at Aug 10, 2026, 4:58:16 AM | |
| Posted by narnal at May 6, 2017, 11:12:43 AM |
cant not open, 'modify walls...' dialogue Right click 'Modify Wall' on 'wall' and 'popup dialog' does not appear. Click again and there is no response. screenshot : https://i0.wp.com/www.dolzikoo.com/wp-content...size=1024%2C720&ssl=1 OS: windows 10 64bit. |
| Posted by Puybaret at May 7, 2017, 12:59:57 PM |
Re: cant not open, 'modify walls...' dialogue Could you check if there's some error log that could explain your issue? Please open a cmd window and run Sweet Home 3D redirecting errors to a file with a command like: "C:\Program Files\Sweet Home 3D\SweetHome3D.exe" 2> Desktop\log.txtIf the file log.txt contains something, please post it here. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Nio at May 13, 2017, 5:00:36 PM |
Re: cant not open, 'modify walls...' dialogue I am also facing the same problem ... |
| Posted by Nio at May 13, 2017, 5:41:50 PM |
Re: cant not open, 'modify walls...' dialogue I get that log.txt file after I launch sweet home 3d by command prompt ....as you said.. |
| Posted by Puybaret at Aug 25, 2017, 8:54:37 PM |
Re: cant not open, 'modify walls...' dialogue The log file you posted reports an error in the look and feel, and I'm not sure I can fix that. Please, try to use a different Windows theme, or run Sweet Home 3D with a different look and feel by adding a file named SweetHome3D.l4j.ini in the same folder as SweetHome3D.exe and writing the following line in it (with the starting hyphen): -Dswing.defaultlaf=javax.swing.plaf.metal.MetalLookAndFeelHope this will work... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 10, 2026, 4:58:16 AM |
