Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: error 40 |
| Print at Sep 21, 2026, 3:04:58 PM | |
| Posted by Miker777 at May 2, 2017, 10:00:21 PM |
error 40 Does anyone know what error 40 means, seen when trying to export a file for html viewing. thx Mike |
| Posted by bdfd at May 3, 2017, 9:12:04 AM |
Re: error 40 Does anyone know what error 40 means, seen when trying to export a file for html viewing. I have already had this 2 or 3 times... thx Mike I think your file is accessed by another user and you can not update it... ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Puybaret at May 3, 2017, 10:22:06 AM |
Re: error 40 The error 40 covers errors that may happen during the export on the server (a little like if the Export to HTML5 plug-in failed). The reason suggested by bdfd is interesting and I should check how to avoid the issue he describes, but in the case of Mike777, it's another issue. The logs on the server report that it's due to a damaged .sh3d file. So please double check if the .sh3d file you submitted can be opened in Sweet Home 3D (maybe you copied it in a different file). I also made some adjustments that could fix your issue (even if I don't believe in this option), so please try again. Then if it still happens, please tell us. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Miker777 at May 5, 2017, 1:56:18 PM |
Re: error 40 The file continues to open ok with Sweet home, i tried both compressed and uncompressed, managed to get it to upload eventually but on by removing 1 of the roof sections i had made with sketchup, thx for your help. Mike |
| Posted by Puybaret at May 6, 2017, 1:56:50 PM |
Re: error 40 Interesting... that could mean that the tool could not transform to OBJ format this roof section at DAE format. Please, try to create a simple .sh3d file with that section and export it. Then if it fails, send it to me because that should help me to fix a potential bug. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Miker777 at May 6, 2017, 3:38:14 PM |
Re: error 40 ty Emmanuel I created a file with just those 2 roof sections in and it loaded fine, i dont think its a size issue as the ranch file is only 7'688 kb, and the roof file is just 26 it is here and the ranch is here. Thanx in advance Mike |
Current timezone is GMT Sep 21, 2026, 3:04:58 PM |
