Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Wall's axis change |
| Print at Sep 25, 2026, 5:35:31 AM | |
| Posted by rdmhora at Apr 25, 2017, 2:12:07 AM |
Wall's axis change Hello every one! When I'm going to draw the walls I type the size that I want, but when I draw the next wall the previous wall size change duo to thickness. This happens because the wall's axis is set in the center of wall. How can I change to be on the left or the right of the wall? |
| Posted by Puybaret at Apr 25, 2017, 9:59:00 AM |
Re: Wall's axis change Sorry, there's no way to change the central axis used to measure walls length. If you don't want to calculate the difference, a workaround could be to draw first rooms and double click in the room with the wall creation tool to create the walls around it. But this won't be a perfect solution either if the walls must have different thicknesses or if you want to draw more than a room. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 25, 2026, 5:35:31 AM |
