Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: SH3d 5.4 On MacOS Sierra and Macbook Air not working |
| Print at Sep 6, 2026, 5:56:55 AM | View all posts in this thread on one page |
| Posted by sfcfs at Apr 22, 2017, 1:32:15 AM |
SH3d 5.4 On MacOS Sierra and Macbook Air not working Using the Java Web Start application. App opens the Menu appears. However, all of the menu items are grayed out except "Open recent home." When I click one of the plans, nothing happens and application hangs. Cannot quit from menu, but kill the process from terminal. The Java Console when shown shows a bunch of security warnings: Insecure property: (com.eteks.sweethome3d.applicationId, SweetHome3D#JavaWebStart) specified in unsigned j Insecure property: (com.eteks. sweethome3d.deploymentInformation, Java Web Start) specified in unsigned jn Insecure property: (j3d. rend, jog t) specified in unsigned jnlp file wilt not be set. Insecure property: (apple.awt.graphics.UseQuartz, true) specified in unsigned jntp file wilt not be set. Java Web Start 11.131.2.11 x86_64 Using DRE version 1.8.Ø_131-b11 Java Hotspot(TM) 64-Bit Server VM And then shows an Exception: Exception in thread "AWT-EventQueue-2" java.lang.ExceptionInInitializerError at com.eteks.test.VideoPlugin.<init>(VideoPlugin.java:133) at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) at java.lang.reflect.Constructor.newInstance(Constructor.java:423) at java.lang.Class.newInstance(Class.java:442) at com.eteks.sweethome3d.plugin.PluginManager.getPlugins(Unknown Source) at com.eteks.sweethome3d.plugin.HomePluginController.getPlugins(Unknown Source) at com.eteks.sweethome3d.swing.HomePane.<init>(Unknown Source) at com.eteks.sweethome3d.swing.SwingViewFactory.createHomeView(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController.getView(Unknown Source) at com.eteks.sweethome3d.HomeFramePane.<init>(Unknown Source) at com.eteks.sweethome3d.HomeFrameController.getView(Unknown Source) at com.eteks.sweethome3d.HomeFrameController.displayView(Unknown Source) at com.eteks.sweethome3d.SweetHome3D$4.collectionChanged(Unknown Source) at com.eteks.sweethome3d.model.CollectionChangeSupport.fireCollectionChanged(Unknown Source) at com.eteks.sweethome3d.model.HomeApplication.addHome(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.showDefaultHomeFrame(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.start(Unknown Source) at com.eteks.sweethome3d.SweetHome3D$5.run(Unknown Source) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756) at java.awt.EventQueue.access$500(EventQueue.java:97) at java.awt.EventQueue$3.run(EventQueue.java:709) at java.awt.EventQueue$3.run(EventQueue.java:703) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80) at java.awt.EventQueue.dispatchEvent(EventQueue.java:726) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93) at java.awt.EventDispatchThread.run(EventDispatchThread.java:82) Caused by: java.security.AccessControlException: access denied ("java.util.PropertyPermission" "com.eteks.sweethome3d.resolutionScale" "read") at java.security.AccessControlContext.checkPermission(AccessControlContext.java:472) at java.security.AccessController.checkPermission(AccessController.java:884) at java.lang.SecurityManager.checkPermission(SecurityManager.java:549) at com.sun.javaws.security.JavaWebStartSecurity.checkPermission(Unknown Source) at java.lang.SecurityManager.checkPropertyAccess(SecurityManager.java:1294) at java.lang.System.getProperty(System.java:717) at com.eteks.sweethome3d.swing.SwingTools.getResolutionScale(Unknown Source) at com.eteks.sweethome3d.swing.ScaledImageComponent.<clinit>(Unknown Source) ... 34 more It seems to be something with security, do not know how to proceed from here. Thanks in advance for your help! |
| Posted by Puybaret at Apr 22, 2017, 6:37:45 PM |
Re: SH3d 5.4 On MacOS Sierra and Macbook Air not working You must have tried a plug-in that blocks the launch of Sweet Home 3D. In the Finder, select Go > Go to folder menu item, and copy paste the folder name ~/Library/Application Support/eTeks/Sweet Home 3D/plugins (with the tilde sign) and remove the plug-in(s) you'll find there. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by sfcfs at Oct 21, 2017, 10:48:14 PM |
Re: SH3d 5.4 On MacOS Sierra and Macbook Air not working Bonjour Emmanuel, Thanks so much for your help. Sorry for the delay in responding, I had been using the JAR version instead and totally forgot about my post. With the update to High Sierra wanted to try again and found your answer. It worked perfectly. Will test to see which plugin was at fault. Merci Beacoup, Christian |
Current timezone is GMT Sep 6, 2026, 5:56:55 AM |
