Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Mac OSX - Case sensitive file system (JRELoadError) |
| Print at Aug 22, 2026, 5:14:51 AM | |
| Posted by fredhags at Apr 14, 2017, 6:50:40 PM |
Mac OSX - Case sensitive file system (JRELoadError) Hi, SH3D is another software in the line of softwares that doesn't work with case sensitive file system. If I try to run it from "Applications" I get an JRELoadError. But if I copy "Sweet Home 3D.app" to an USB stick the software runs fine. This isn't the first software where I have seen this problem. It's 2017, this shouldn't be a problem ![]() |
| Posted by Puybaret at Apr 14, 2017, 7:15:19 PM |
Re: Mac OSX - Case sensitive file system (JRELoadError) Could it be a clue about the infamous JRELoadError? ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by fredhags at Apr 14, 2017, 7:33:54 PM |
Re: Mac OSX - Case sensitive file system (JRELoadError) I think so yes. Normally you don't experience this problem when you are running only OSX. But when you are a "MashUp-person" running Win/*nix/OSX you see it it from time to time. Case sensitivity has been around for a long time in the *nix world. |
| Posted by Puybaret at Apr 14, 2017, 7:52:34 PM |
Re: Mac OSX - Case sensitive file system (JRELoadError) I just tried to run the Mac App Store version of Sweet Home 3D from a USB key formatted with the case sensitive option, and confirm I got a JRELoadError. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by fredhags at Apr 14, 2017, 7:54:30 PM |
Re: Mac OSX - Case sensitive file system (JRELoadError) But if you try to format it ExFAT and try to run it from there? |
| Posted by Puybaret at Apr 14, 2017, 9:01:36 PM |
Re: Mac OSX - Case sensitive file system (JRELoadError) My problem was how to reproduce the JRELoadError issue, not how to avoid it! Many thanks for posting your message. It seems that using the Java launcher generated by javapackager fixes this issue ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Apr 14, 2017, 11:52:08 PM |
Re: Mac OSX - Case sensitive file system (JRELoadError) To fix this issue on the existing version, you should click on the application icon of Sweet Home 3D while maintaining the ctrl key pressed to display its contextual menu, choose Show Package Contents item, open the Contents folder and rename the folder Plugins as PlugIns (with an uppercase I). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by fredhags at Apr 15, 2017, 5:40:44 AM |
Re: Mac OSX - Case sensitive file system (JRELoadError) Thank you!!! |
| Posted by Puybaret at Jun 14, 2017, 2:24:41 AM |
Re: Mac OSX - Case sensitive file system (JRELoadError) The version 5.4.2 released tonight fixed this error. Thanks again for your help ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 22, 2026, 5:14:51 AM |
