Print at Jul 27, 2026, 8:24:13 PM
Posted by bdfd at Apr 7, 2017, 12:33:06 PM
ALERT : Win10 build 1703
After download and installing new Win10 build 1703, I saw that sh3d crashed !
In opening, no problem.
I tryed to do a 'Save Under...' and bye...
No message...
When you re-try to open sh3d's file, do a simple 'Save' on a recuperated file, this resoluted the problem.
So, becareful !
====> 04-07-2017 - 15:21 GMT
1. Same crash when I want to import new model in existant project.
When I choose 'Furniture', 'Import furniture', 'choose model'........... CRASH ! similar to departure without saving.
2. Same thing on new project with an import.
Here is the latest log
devilish
Attachment hs_err_pid8328.log (44059 bytes) (Download count: 40735)
Posted by bdfd at Apr 8, 2017, 9:05:44 AM
Re: ALERT : Win10 build 1703
Today, same crash in saving on rendering picture... devilish
Here is the most recent log...
Attachment hs_err_pid14292.log (44583 bytes) (Download count: 25432)
Posted by korner at Apr 8, 2017, 12:06:35 PM
Maybe, that's because of non-ASCII characters in folder name?
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j sun.awt.shell.Win32ShellFolder2.getDisplayNameOf(JJI)Ljava/lang/String;+0
j sun.awt.shell.Win32ShellFolder2.access$1600(JJI)Ljava/lang/String;+4
j sun.awt.shell.Win32ShellFolder2$13.call()Ljava/lang/String;+15
j sun.awt.shell.Win32ShellFolder2$13.call()Ljava/lang/Object;+1
java_command: com.eteks.sweethome3d.SweetHome3D -open D:\SH3D\Crйations\06 Cubique\10\Cubique10 meublйe.sh3d
Sure this is a bug author needs to fix, but I can see a workaround in renaming that folder
Posted by bdfd at Apr 8, 2017, 12:21:31 PM
Good idea but LOST ! crying
Same crashes without french accents...
Posted by bdfd at Apr 9, 2017, 10:23:01 AM
Fortunately, the option 'Save and compress' works fine !
Posted by bdfd at Apr 11, 2017, 9:49:48 PM
@Manu : What are the news ?
Posted by Puybaret at Apr 12, 2017, 11:54:53 AM
It looks like the Java bug #8170517 or #8173471. The first one was closed as non-reproducible and the second one was resolved recently but the fix is probably not published yet.
The bug must happen as soon as you try to access a file dialog box to choose a sh3d file or any other file handled by Sweet Home 3D, with a problem to access this file.
To cancel the directories that you used recently in Sweet Home 3D, run regedit, search for last/Directory# and last/Default/Directory in folders ending with com/eteks/sweethome3d and remove matching entries.
If it doesn't work better after that, try to move and open a Sweet Home 3D file in a very common place like your desktop to check if it works better or not.
Posted by bdfd at Apr 12, 2017, 1:04:57 PM
No change after remove all entries in "\HKEY_CURRENT_USER\Software\JavaSoft\Prefs\com\eteks\sweethome3d"... crying
Same crash with :
- Save Under
- choose new furniture
- save picture...
Why does it work with 'Save and compress' and NOT with 'Save' or 'Save as' ?
Another ideas ?
perhaps with java 1.9 ?
Posted by Puybaret at Apr 12, 2017, 11:09:32 PM
I just tried on a Windows 10 computer with Creator update (version 1703 / 15063.138), and didn't notice any issue.
You can try with Java 9 + Jar executable version for example, but keep in mind that Java 9 is still in Beta.
Posted by bdfd at Apr 13, 2017, 9:49:33 AM
OK, we have same OS with the latest update (yesterday).
The link to download java9 is HERE cool
Here are the problems :
Java 9 is installed, After reboot I saw this :
Always in java 1.8 ! sick
So I saw a sub-directory jre8 in sh3d directory, I deleted it.
I launched sh3d and...
So I copied/pasted the jre-9 in programs directory into sh3d directory.
I deleted all plug-ins, same crashes... devilish
I desactived my anti-virus, same crashes... sick
Latest updates after win10 1703
here is the latest logs :
What can I do more ?
Even the soft "Furniture Library Editor" crashes... talk to the hand
see the last joined log.
Attachment hs_err_pid3352.log (41147 bytes) (Download count: 39374)
Attachment hs_err_pid1572.log (41234 bytes) (Download count: 26932)
Attachment hs_err_pid11088.log (41477 bytes) (Download count: 16960)
Attachment hs_err_pid13688.log (26380 bytes) (Download count: 25694)
Posted by Puybaret at Apr 13, 2017, 10:49:38 AM
As suggested in my previous post, please try with the Jar executable version.
Posted by bdfd at Apr 13, 2017, 11:02:09 AM
OK, it's done.
I launched it by double-click on jar file and...
I saw only this :
And no more ?
No log !
Posted by Puybaret at Apr 13, 2017, 11:15:39 AM
Even if Java 9 is still in beta version, I wished the program could run a little further sad
You could launch the program in a cmd window with a command like:
java -jar path\to\SweetHome3D-5.4.jar
The logged errors displayed in the console you give some hints to go further...
Posted by bdfd at Apr 13, 2017, 11:31:54 AM
Thanks Manu.
Here is the log of the command :
And I forgot the log's file (xxx8304.log) with return on java 1.8.0_51 :
Attachment j9log.txt (3378 bytes) (Download count: 60293)
Attachment hs_err_pid5972.log (41011 bytes) (Download count: 40393)
Attachment hs_err_pid8304.log (32075 bytes) (Download count: 40569)
Posted by bdfd at Apr 13, 2017, 4:07:08 PM
A new downloading and installation of Win10 build 1703 (15063.138) on a mobile computer (core i3) gave EXCELLENT results... applause
I do same thing on my another desktop !
I don't understand... crying
Posted by bdfd at Apr 14, 2017, 8:57:46 AM
This morning, a new installation of Win10 build 1703 (15063.138) on my desktop (core i7) did not give good results... crying
sh3d always crashes... devilish
Same thing with sh3d 4.6 & 5.3 !
Posted by bdfd at Apr 14, 2017, 7:54:14 PM
Do you have any news about my problem seen on apr 07th ? sad
I think to make a good diagnosis, you just compare why there are differences between 'Save' (NOK) and 'Save and compress' (OK) actions and find out what can cause these crashes, right ?
We have the effects, you must find the reason... and the solution.
I hope that the last logs are speaking themselves.
Posted by Puybaret at Apr 15, 2017, 12:04:55 PM
As said before, this bug seems to be bound to the file dialog box, and on a brand new document, all menu items Save, Save as, Save and compress as well as Open must crash the application in your case. Is it right?
Posted by bdfd at Apr 15, 2017, 12:39:39 PM
Absolutely no !
In file menu
New : OK
Open : Nok
Open recent files : OK
Save : Nok
Save as : Nok
Save and compress : OK
In Furniture menu
Import Furniture, choose : Nok
Import Furniture bib : Nok
Import Texture : choose picture : Nok
Option Create photo
Save : Nok
To understand better , we can write on french section. love struck
Posted by bdfd at Apr 16, 2017, 9:18:39 AM
@Manu, more news !
Print in pdf : Nok
Import texture lib : Nok
Export to csv : Nok
Export to svg : Nok
Create video, save : Nok
Export to obj : Nok
Export to html5 : Nok
All other options didn't crash !
sad crying shock sick angry
Posted by Puybaret at Apr 16, 2017, 7:39:19 PM
You seem not to be alone, something that should help to find and test a solution, if ever something comes to mind.
Posted by bdfd at Apr 17, 2017, 8:40:30 AM
Great ! angry
I'm not alone... and the online version crashes too.
We hope quickly a solution ! tongue
Posted by bdfd at Apr 18, 2017, 11:45:31 AM
NEWS !
Today, I tried to install a new tool into sh3d.
And mystery, it didn't appear in tool menu ! devilish and No in list of librairies in about menu... angry
Quick Manu, where are you ? crying
Do you know what to do confused
Attachment hs_err_pid11056.log (40053 bytes) (Download count: 16388)
Posted by Puybaret at Apr 18, 2017, 11:57:01 AM
Please use ticket #743 to follow news about this bug.
Posted by bdfd at Apr 18, 2017, 12:24:28 PM
OK.
I log in.
I downloaded the jar... and it works !
Except for rendering photo...
What is the next step ?
Posted by Puybaret at Apr 18, 2017, 12:28:16 PM
What do you mean???
Posted by bdfd at Apr 18, 2017, 12:29:34 PM
What do you mean???
Perhaps a new exe (in 64 bits to be faster) ?
Posted by Puybaret at Apr 18, 2017, 12:44:25 PM
Not now. Let's see how Microsoft or Oracle will fix this issue.
Posted by bdfd at Apr 18, 2017, 12:49:06 PM
Oh my god ... technical unemployment ! crying sick
Posted by Puybaret at Apr 18, 2017, 1:11:41 PM
The proposed Jar works, doesn't it?
Posted by bdfd at Apr 18, 2017, 1:55:47 PM
Not at 100%.
Rendering photo crashs in stopping on screen !
Posted by Puybaret at Apr 18, 2017, 2:09:10 PM
Use -Xmx Java parameter but before all, please, don't post your comments in 2 different places.
Posted by bdfd at Apr 18, 2017, 2:22:47 PM
Same thing !
but when I replace a cecilia's texture of grass by a standard texture for the ground, it's better but slower and the crash is later ???
Strange !
Posted by bdfd at Apr 18, 2017, 5:53:52 PM
NEWS
I deleted old version of java and I downloaded java 1.8.0_121 64 bits from oracle.com and I installed it again.
At this moment, with the new jar (5.4a) of Manu, the soft is OK.
No slow, no crah, in waiting for the defintive exe... smile
