Print at Aug 15, 2026, 7:19:11 PM View all posts in this thread on one page
Posted by sergiopss at Mar 31, 2017, 6:39:18 PM
Generated Photo is always blank
After adding a room to my project, after that moment I can't generate anymore a photo or video in hight quality when using "Virtual Visit" view since the generate image is always blank.
If I delete the room is ok again.
Here is a print screen for best understanding: IMAGE
I've searched for possible fix but without results...
Any help?
Thanks.
Posted by bdfd at Mar 31, 2017, 7:15:06 PM
Re: Generated Photo is always blank
Any help?
Thanks.
I had the same problem after adding a fairly large object. crying
We have thus reached the possibilities of the software (either in memory or in the number of objects present, ...).
You need to simplify your project...
Posted by sergiopss at Mar 31, 2017, 7:43:37 PM
Hi, thanks for the reply but that's not a solution since I'm only making a simple prototype... I only have about 10 simple objects and this only happens when I add the room, even without textures.
Posted by sergiopss at Mar 31, 2017, 8:09:08 PM
Hummm, my bad...
I just realize that my view probably was above the ceiling (can't realize that on the 3d view).
When rendering, it was rendering by beautiful white ceiling...
Problem solved!
Posted by bdfd at Mar 31, 2017, 9:29:26 PM
Hummm, my bad...
Problem solved!
OK !
The center of the point of view had moved... laughing
