Print at Aug 16, 2026, 4:57:52 AM
Posted by SchokiDay at Mar 15, 2017, 12:18:29 PM
3DS not importing properly - textures missing
Is this just a crappy design or am I importing the *.3DS wrong.
All textures are missing sad
Example here:
http://fs5.directupload.net/images/170315/qts6z6us.jpg
Thanks in advance ;)
Posted by Puybaret at Mar 16, 2017, 6:24:53 AM
Re: 3DS not importing properly - textures missing
It's probably an issue with the encoding of Cyrillic characters in the 3DS file.
How did you get this 3DS file?
Posted by SchokiDay at Mar 16, 2017, 7:15:26 AM
Thanks for the response!
I downloaded some 3D Objects on "https://archive3d.net/"
I am pretty new with this program and still testing all cind of things.
Posted by hansmex at Mar 16, 2017, 7:41:19 AM
It's a known problem that some/many of the models at archive3d.net miss textures.
Can you give a direct link to one of the models that causes problems?
Posted by SchokiDay at Mar 16, 2017, 9:11:27 AM
Hi hansmex,
i happened to find the example (flowers) shown in my picture-link:
"https://archive3d.net/?a=download&id=83a105e8"
It doesnt apply the blossom texture or maybe i am doing something wrong?
And thx for all the halp so far wink
Posted by Puybaret at Mar 16, 2017, 9:56:46 AM
This 3D model contains data at two formats that Sweet Home 3D is able to handle:
- OBJ format, but this one can't work because its accompanying MTL file it contains doesn't reference any texture image
- 3DS format, but the 3DS file references only one texture image instead of the 7 available images, and the non latin characters prevents it to work.
If you want my opinion, the submitter of this nice model didn't try the OBJ and 3DS exports he proposed in an other software.
Posted by SchokiDay at Mar 16, 2017, 10:57:25 AM
Thx a lot for your replies!
So its not a general problem rather then incompatible or bad modeling for sweet home 3D?
Since we are at it, i would have a followup question if its not to much :) ...concerning importing textures. Maybe you can also help me out here or i will simply open a new thread.
Anyway:
Can u skale textures after importing them?
Why i ask? -> while importing textures you have the option to skale textures, but i sometimes cant seem to find the right skale for my objects for them to connect right. So i "remport" and skale again and again until it suits my objects.
Or is there anything i have to check while importing and skaling?
Again, thanks a lot already!
Posted by hansmex at Mar 16, 2017, 8:00:14 PM
If it's a texture you imported yourself, the name of the texture appears in italics.
- select the texture
- click Modify
- change the appearance
Posted by SchokiDay at Mar 17, 2017, 1:34:38 PM
Yes, thanks for this solution applause
