Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: macOS Sierra - Sweet Home 3D 5.4 - very slow |
| Print at Aug 19, 2026, 7:13:37 PM | |
| Posted by denis_sh3d at Mar 5, 2017, 8:21:38 AM |
macOS Sierra - Sweet Home 3D 5.4 - very slowGood morning, I've updated to macOS Sierra coming from EL Capitan and since this update Sweet Home 3D is running pretty sluggish. The 3D view is stuttering and the whole 2D view is slow as well. I got an i7 processor with 16 GB of RAM so this should be fine. Other java stuff like Android Studio or Minecraft does run normally. Has someone experience the same and can help me? Thank you very much. Denis |
| Posted by denis_sh3d at Mar 5, 2017, 8:31:06 AM |
Re: macOS Sierra - Sweet Home 3D 5.4 - very slow I'd like to add even when giving it more than the 1GB max RAM (4096 or even more) it does run pretty slow. :( |
| Posted by bdfd at Mar 5, 2017, 9:10:08 AM |
Re: macOS Sierra - Sweet Home 3D 5.4 - very slow Hi, What is the version of SH3D ? => 5.4 ? What is the size of the SH3D file which gives this problem ? ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by denis_sh3d at Mar 5, 2017, 6:56:06 PM |
Re: macOS Sierra - Sweet Home 3D 5.4 - very slow Hi, The Version is 5.4. The filesize is 48MB. I am using the project on my Macbook Pro for now running Yosemite since it is unusable on macOS Sierra. (the Macbook Pro is less powerful with less RAM) Yesterday I was using the the same machine with El Capitan and it was fast and smooth. Today on macOS Sierra it is sluggish like hell. Even resizing the 2D window is damn slow. I'm open for every advice. If I can deliver more logs or something else for debugging the problem just drop me a message and I'm collecting it for you. Thank you very much. Denis |
| Posted by Puybaret at Mar 6, 2017, 1:35:33 PM |
Re: macOS Sierra - Sweet Home 3D 5.4 - very slow I would suggest to install Java 8 and try the Java Web Start version. As this version will use an other version of Java and of the 3D engine, it might run better. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by denis_sh3d at Mar 9, 2017, 6:34:18 PM |
Re: macOS Sierra - Sweet Home 3D 5.4 - very slow The web start version does run smooth as silk. :-) Thank you very much. |
| Posted by denis_sh3d at Mar 11, 2017, 10:50:03 PM |
Re: macOS Sierra - Sweet Home 3D 5.4 - very slow The only problem remaining is that I am not able to render images at the best quality level anymore. I'm getting a red cross. This did work with the normal download version of Sweet Home 3D. Any suggestions? |
| Posted by VeroniQ at Mar 12, 2017, 12:49:27 AM |
Re: macOS Sierra - Sweet Home 3D 5.4 - very slow I suggest that you read, in the FAQ, this chapter: How can I adjust the memory used by Sweet Home 3D? |
| Posted by bdfd at Mar 12, 2017, 6:33:04 AM |
Re: macOS Sierra - Sweet Home 3D 5.4 - very slow The only problem remaining is that I am not able to render images at the best quality level anymore. I'm getting a red cross. This did work with the normal download version of Sweet Home 3D. Any suggestions? I has had the same problem more times when the projects had too objects inside.With a copy, try to remove few objects and try again... ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by denis_sh3d at Mar 12, 2017, 10:14:48 AM |
Re: macOS Sierra - Sweet Home 3D 5.4 - very slow Thank you very much. Is there a way to raise the available memory to the web starter version of SH3D? |
| Posted by Puybaret at Mar 13, 2017, 4:21:41 PM |
Re: macOS Sierra - Sweet Home 3D 5.4 - very slow Is there a way to raise the available memory to the web starter version of SH3D? Unfortunately not without creating an other jnlp file. I wanted to request a larger memory size for 64 bit architecture like I did for Windows and Linux, but it wasn't possible under macOS because of a bug. Anyway, here's a link to another Java Web Start version that will request 4GB max but will work only under 64 bit systems.You could also use the Jar executable version, but you would lose the file association with .sh3d files. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 19, 2026, 7:13:37 PM |
