Print at Aug 19, 2026, 9:36:45 AM
Posted by bdfd at Feb 2, 2017, 2:34:33 PM
cool   The martian odysseys
D 714 - Nov 11th 2041
Mars III (ISV GAGARIN ) is arrived correctly around martian orbit.
This new crew prepares his descent and verify all the vessel.
Bigger, faster than the previous ISV Hermes.
1900 x 1400 in Q4 for the model and Celestia for the background.
Here are the positions of the interior planets at D 714.
The new crew has 8 members.
4 modules will depart from martian orbit:
2 Matmod v3 (Material module)
1 MRV v3 (Martian Return Vehicle) and
1 Habmod v3 (Habitation module)
Posted by bdfd at Feb 4, 2017, 4:49:47 PM
Re: The martian odysseys
D 715 - Nov 12th 2041
In the beginning of the morning, the first Matmod (V3) is separated itself from ISV Gagarin.
1920 x 1080 in Q4
In the end of the afternoon, the matmod is arrived on Mars at 1 km at north from base camp.
Posted by VeroniQ at Feb 5, 2017, 10:16:23 PM
Good luck to this new crew!
Posted by bdfd at Feb 6, 2017, 7:08:05 AM
Thanks Lady Vero. wink
Because of the firing windows the crews 2 and 3 will work together for nearly 1.5 years.
To give an idea with the previous matmods, here a photo of family with a 'martionaut' to see the sizes.
The specifications :
And the model 3D HERE
Posted by bdfd at Feb 8, 2017, 6:49:56 AM
D 716 - Nov 13th 2041
The second Matmod is arrived.
The first crew sends an martionaut to verify that all is good in waiting the arrival of the second crew.
1920 x 1080 in Q4
There are plenty of surprises in these modules ...
Posted by bdfd at Feb 10, 2017, 7:14:40 AM
D 717 - Nov 14th 2041
The Habmod v3 is arrived on martian ground near the northern border of Taytay crater.
1920 x 1080 in Q4
To give you an idea with the previous habmods, here a photo of family to compare the sizes.
And the specifications
This model like the previous is entirely made with SH3D.
And the model 3D is HERE
Posted by bdfd at Feb 13, 2017, 7:21:42 AM
D 719 - Nov 16th 2041
The MRV 'condor' left ISV Gagarin to fetch the 3 astronauts on the ISV Hermes-Mercury (see HERE) which will now be in automatic mode.
One day to go get them and another to go down to Mars.
8 + 3 = 11, this is the maximum passenger embarked in a MRV.
The MRV v3 is arrived on martian ground near the 'MRV Mars II site' in west direction of Taytay crater.
1920 x 1080 in Q4
To give you an idea with the previous MRV, here a photo of family to compare the sizes.
You can see an added stage to go higher in martian orbit and which can embark more hardware at return.
Like the previous, it is entirely made with SH3D.
Posted by bdfd at Feb 14, 2017, 5:41:29 PM
The second crew disembarks and is taken over by the rover (in two times) to be brought to the Habmod v2 (at base camp) released by the first crew.
1920 x 1080 in Q4
They will undergo medical examinations and a small quarantine so as not to contaminate the first crew.
In the map below, you see the new locations of Mars III.
The habmod v3 is near the future greenhouses.
It will serve like refuge and laboratories.
On the way, the second crew will find the two Matmod V3.
Posted by bdfd at Feb 17, 2017, 4:19:59 PM
D 720 - Nov 17th 2041
All modules of Mars III and crew are on Mars.
We can see below the new sites of Mars III (Matmod & Habmod) with the traces of the rover1.
1920 x 1080 in Q4 reduced in 1024 x 768
With good eyes, far away between the two Matmod, there is the Habmod and the next greenhouses area (follow the traces at left).
Posted by bdfd at Feb 19, 2017, 8:06:07 AM
D 734 - Dec 01st 2041
After the quarantine, the second crew (8 members of 4 couples*) begins to desembark the new equipments.
(*) : 1 US couple, 1 russian, 1 european and 1 hindu.
1920 x 1080 (reduced in 1024 x 576 on imgbox because mediafire is sick) in Q4
In first stage of Matmod v3, you see a lift for the new rover v2 in front view with lights on.
In same time, two marsonauts (or martionauts) go out the cranes to go down the equipments from the higher levels.
Posted by bdfd at Feb 22, 2017, 6:48:21 AM
Here are the two new rovers...
Bigger, faster, with more autonomy and I find it prettier...
Posted by AeowynFraser at Feb 22, 2017, 8:44:41 AM
I am awed at the creativity that has gone into each of these!
Posted by bdfd at Feb 22, 2017, 10:54:10 AM
Thank you Aeowyn, maybe there are many persons in my head ??? laughing
Here is the model 3D HERE of this rover2.
Posted by bdfd at Feb 23, 2017, 6:52:12 AM
Closer views on the new rovers.
and
1920 x 1080 in Q4
In front of to rover1 (follow the traces), they find the base camp.
Before to use them, they must be charged by the sun... cool
Posted by bdfd at Feb 24, 2017, 4:29:11 PM
D 735 - Dec 2nd 2041
During rovers 2 loading, rover 1 goes to habmod to activate it.
The rest of the team unpacks the boxes and starts using the 3D printer to launch the production...
Posted by bdfd at Feb 26, 2017, 7:18:23 AM
D 780 - Jan 16th 2042
To connect all rovers with the base camp, the crews need a new 'building', it's the Roverport.
You are in inflatable section between the Base camp's hangar and the roverport.
450 x 768 in Q4
One time inside the roverport you are in pressurized section.
1024 x 768 in Q4
You must climb the stairs to arrive in airlocks section.
Posted by bdfd at Feb 28, 2017, 7:50:55 AM
Three accesses were done:
=> one for rover type 1 (rectangular and telescopic) at right on picture
=> two for rover type 2 (circular) in front and rear.
At left, you go back to the base camp.
1024 x 768 in Q4
You see a marsonaut going out from a rover2.
Posted by bdfd at Mar 4, 2017, 6:43:47 AM
The second access for rover type 2 (right side)
For rover type 1.
Inside with the attached rover.
1024 x 768 in Q4
Posted by bdfd at Mar 10, 2017, 6:41:53 AM
Outside views of the roverport from the hangar.
1024 x 768 in Q4
You can see thru the inflatable tunnel the two new rovers (front and rear) on each side of the roverport.
Posted by bdfd at Mar 15, 2017, 7:45:16 AM
Here is a general south-east view of the roverport connected to the hangar and the cupola with a rover type One and the newer rover type Two.
1920 x 1080 in Q4
Posted by VeroniQ at Mar 15, 2017, 10:51:24 AM
The cupola and the rover look great, now! How do you obtain this aluminium effect? Is it a special texture?
Posted by bdfd at Mar 15, 2017, 11:00:15 AM
No, it is a blue dome with a semi-transparent glass and according to the time and angle of view we have this effect... cool
1st view
Another view
Posted by bdfd at Mar 21, 2017, 7:27:31 AM
D 824 - Mar 01st 2042
The printers 3D have worked strongly to start the next project : The greenhouses.
Fisrt step : Go to the northern crater for the access for them.
1920 x 1080 in Q4
The first crew has already begun to spread the rocks and the second builds the airlock.
Posted by bdfd at Mar 24, 2017, 6:59:35 AM
D 856 - Apr 02nd 2042
The second part in the project "greenhouses" is the arrival of the second roverport.
1920 x 1080 in Q4
The roverport is connected with the airlock behind the solar panels.
The first crew continues to take the rocks to meet them in little hills and the second builds the roverport.
Posted by bdfd at Mar 29, 2017, 9:22:11 AM
D 860 - Apr 06th 2042
All nodes are connected !
1920 x 1080 in Q4
Greenhouses Airlock <-> Roverport <-> Habmod v3
Habmod will serve for refuge and laboratories...
Posted by bdfd at Apr 1, 2017, 11:22:46 AM
D 920 - June 05th 2042
First greenhouse has been built with transparant walls, a good ground has been placed.
1920 x 1080 in Q4
Posted by VeroniQ at Apr 1, 2017, 7:01:05 PM
Potatoes, like Matt Damon ;-) ? Salads?...
Posted by bdfd at Apr 2, 2017, 8:20:45 AM
No for the beginning tongue , the crew will grow green vegetables sick .
These will enrich the soil.
Salads, probably in addition to mine... laughing
Posted by bdfd at Apr 4, 2017, 5:23:56 PM
D 925 - June 09th 2042
The seeds are sown and the gardener sprinkles his seedlings.
1920 x 1080 in Q4 with R1.3.2 (AA:2/3, gI:def, dB/cP: 1/0, sS:glossy, nlfD/nlr: 250/1, f/sA:backman/bucket, sbs=4) in 16 mn.
Later, an automatic sprinkler will do the job.
Posted by bdfd at Apr 10, 2017, 9:21:28 AM
D 960 - July 14th 2042 : French National Day
The first greenhouse gives its first vegetables.
1920 x 1080 in Q4 with R1.3.2 (AA:2/3, gI:def, dB/cP: 1/0, sS:def;nlfD/nlr: 250/1, f/sA:michell/bucket, sbs=0) in 19n.
The second greenhouse is ready for the seedlings.
Posted by bdfd at Apr 17, 2017, 8:16:57 AM
D 961 - July 15th 2042
The interior view of the first greenhouse.
1024 x 768 in Q4 with R1.3.2 (AA:2/3, gI:def, dB/cP: 1/0, sS:def;nlfD/nlr: 250/1, f/sA:michell/bucket, sbs=0) in 11 mn.
You see the automatic sprinkler near the gardener.
Posted by bdfd at Apr 22, 2017, 10:47:29 AM
D 991 - Aug 14th 2042
The two greenhouses are operational.
1920 x 1080 in Q4
The base for the main greenhouse has been made.
Posted by bdfd at Apr 27, 2017, 11:24:55 AM
D 1106 - Dec 07th 2042
The structure of the main greenhouse is finished.
1920 x 1080 in Q4
The greenhouse must be high to be the 'home' of the future trees...
Posted by VeroniQ at Apr 27, 2017, 5:52:26 PM
Your crews are working hard and well!
Posted by MartinSK at Apr 28, 2017, 8:05:22 AM
green house......it sounds good for my "green age" of these days.... nice work guy
Posted by VeroniQ at Apr 28, 2017, 2:36:11 PM
About greenhouses, on Earth or Mars, I remind this interesting interview in the blog
Posted by bdfd at May 2, 2017, 7:56:16 AM
Thanks all !
D 1150 - Jan 20th 2043
The triple glassed Windows have been installed and pressurized.
1920 x 1080 in Q4
All accesses are operational, without spacesuit the crew can go from habmod to main greenhouse in going by the roverport.
The two vegetables greenhouses have already given a second season.
The rests must serve to made the ground for the main greenhouse.
Posted by Miker777 at May 2, 2017, 10:46:59 PM
Thats impressive work bdfd, nice one.
Posted by bdfd at May 5, 2017, 12:32:05 PM
TY Miker.
This part of Mars III's project is equal to 6,000 by 6,000 meters.
It begins to be heavy !
D 1176 - Feb 15th 2043
Three Wind-turbines have been installed.
1920 x 1080 in Q4
In case of day without solar power because a storm should be on the site, electricity will be available for the greenhouses.
Posted by bdfd at May 9, 2017, 8:21:30 AM
D 1210 - Mar 21th 2043
The reservoirs are not enough, a greater reserve of water is needed.
The team then constructed a drilling well to collect water.
1920 x 1080 in Q4
The radar images and prospecting were right.
They found water at 50 m depth ...
A large deposit to brighten greenhouses (and others) for at least 30 years ...
Posted by bdfd at May 16, 2017, 8:31:43 AM
D 1250 - April 30th 2043
All around, solar panels Have been installed to give the maximum energy to the greenhouse complex.
1920 x 1080 in Q4
The next day is the 'Labor Day', all members will be at rest...
Posted by AeowynFraser at May 16, 2017, 9:16:07 AM
Seeing these, and now I can hardly wait for NASA's Mission to Mars. smile
Posted by bdfd at May 24, 2017, 7:43:21 AM
No problem Aeowyn, your ticket is reserved. laughing
D 1280 - may 30th 2043
The new ground is ready to be put in the greenhouse.
Access is granted...
1920 x 1080 in Q4
Posted by bdfd at Jun 5, 2017, 8:45:25 AM
D 1290 - june 09th 2043
The new ground is inside the greenhouse and the gardeners work.
1920 x 1080 in Q4
A central fountain is OK, water is available. batting eyelashes
Posted by bdfd at Jun 25, 2017, 11:25:23 AM
D 1312 - july 01st 2043
The grass is ready and the gardeners are going to work.
1920 x 1080 in Q4
Remember, the date of the return of the crew of Mars II arrives soon.
They begin to prepare it.
Posted by bdfd at Jul 8, 2017, 9:57:13 AM
D 1325 - july 14th 2043 : French National Day
A general view of the greenhouses site.
1920 x 1080 in Q4 in 10 mn.
Posted by bdfd at Jul 17, 2017, 8:55:13 AM
D 1377 - Sept 04th 2043
In the summer, a new module is arrived from Earth with inside lot of trees...
The gardeners have planted them and they aren't sick !
1920 x 1080 in Q4 in 17 mn.
They have'nt forgotten the bees.
Posted by MartinSK at Jul 17, 2017, 11:42:31 AM
....a part of green nature on red planet...nice....
Posted by bdfd at Jul 17, 2017, 5:15:07 PM
Yes Martin.
A little of sweetness in a world of brutes... wink
Posted by bdfd at Jul 27, 2017, 9:02:32 AM
1417 - Oct 14th 2043
The summer is ending, It's time to Mars II crew to back on Earth.
During the last month, all members have had a choice: stay or go.
Mars is in good location.
Made by celestia in 1,030 x 1,020.
The choice is fallen, half of crew of Mars II stay with Mars III crew !
With half of crew, the ship will be lighter, they could take more rocks of Mars.
The countdown is launched... 5 ... 4 ... 3 ... 2 ... 1 ... 0 !
1,024 x 768 in Q4 in 05 mn
Mars II is gone and a Journey of 180 days begins...
Posted by bdfd at Jul 28, 2017, 10:46:40 AM
Mars II climbs in the martian sky...
Posted by bdfd at Aug 6, 2017, 8:10:50 AM
Mars II goes on to climb in the martian sky...
All is OK.
1,024 x 768 in Q4 in 04 mn
Posted by bdfd at Aug 16, 2017, 8:37:40 AM
H + 02mn30s : Mars II is at height of 60 kms... Main engine cutoff
H + 02mn35s : Separation of first stage.
H + 02mn40s : Stage2 startup...
1,024 x 768 in Q4 in 05 mn with help of Celestia.
Posted by bdfd at Aug 18, 2017, 10:48:12 AM
H + 04mn : Mars II is at height of 150 kms...
Posted by bdfd at Aug 24, 2017, 9:55:35 AM
H + 06mn00s : Mars II is at height of 400 kms... Second engine cutoff
H + 06mn05s : Separation of second stage.
H + 06mn10s : Stage3 startup...
Posted by MartinSK at Aug 24, 2017, 10:37:33 AM
The martian atmosphere looks great. Try to use a little depth of field effect if possible. I am sure it will look superb.
Posted by bdfd at Sep 4, 2017, 10:36:16 AM
H + 15mn00s : Mars II is at height of 1000 kms... Stage3 cutoff
H + 20mn00s : Opening of solar panels
1,900 x 1,000 in Q4 in 05 mn with help of Celestia for background.
Posted by bdfd at Sep 26, 2017, 8:45:15 AM
H + 01h05mn00s : Mars II is near Hermes-Mercury.
1,920 x 1,080 in Q4 in 05 mn with Celestia for background.
Posted by bdfd at Oct 16, 2017, 8:36:48 AM
H + 02h00mn : Mars II is attached at Hermes-Mercury.
1,920 x 1,080 in Q4 in 09 mn with Celestia for background.
Back to Earth !
It's the end of this adventure for Mars II's crew.
Thank all for your encouragments.
Posted by VeroniQ at Oct 16, 2017, 5:21:32 PM
Well done, captain BDFD! A virtual leap for mankind ;-)
