Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Awful performances on Fedora 25 64 bit |
| Print at Aug 20, 2026, 7:41:49 AM | View all posts in this thread on one page |
| Posted by romu70 at Jan 19, 2017, 5:44:47 PM |
Awful performances on Fedora 25 64 bitI updated my (Dell XPS 13 with Skylake Core i7) to Fedora 25 and SW3D performances are so awful that it is barely usable. And as my VirtualBox Windows VMs crash because of the 3D rendering, it's difficult for me to use SW3D. I tested with both Xorg and Wayland, same awful graphics performances. Any idea how to fix this? |
| Posted by Puybaret at Jan 19, 2017, 6:35:03 PM |
Re: Awful performances on Fedora 25 64 bit Maybe try the SweetHome3D-Java3D-1_5_2 script that is also included in Sweet Home 3D download. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by romu70 at Jan 20, 2017, 9:54:08 AM |
Re: Awful performances on Fedora 25 64 bit Much better thanks. I still have latency with the "Create room" feature. Here is what happens: 1. Put the mouse cursor on a corner and wait for the inference engine to display the small blue disk 2. Then click 3. Move to another corner and ...(step 1) 4. Click 5. Move the... -> At that time, there is a big chance the point created at step 4 is not where the inference disk was. As a result, when your room is defined, you have to refine the positions of the points which are not located where they should be. |
| Posted by Puybaret at Jan 20, 2017, 11:11:30 AM |
Re: Awful performances on Fedora 25 64 bit I don't know what you mean by "inference engine" I just tried again under Ubuntu and didn't notice any issue while drawing rooms, even with a virtual machine running under Parallels Desktop. There must be another issue on your computer. You could also try with an older version of Sweet Home 3D because the last version comes with a more recent version of Java, but I would be astonished that it works better. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by romu70 at Jan 20, 2017, 11:35:58 AM |
Re: Awful performances on Fedora 25 64 bit "inference engine" it's just the part of the software you wrote which detect the cursor or an object is getting very close to a particular object (wall, corner, furniture, etc). You use it everywhere in SW3D to show the small blue disk when you draw rooms, to display rules when the user draws walls, etc... You just didn't know this is called inference. Ok, I'll can live the way it works right now with the 1.5.2 script. Thanks a lot for the help. |
| Posted by Puybaret at Jan 20, 2017, 7:32:08 PM |
Re: Awful performances on Fedora 25 64 bit (Sorry for English readers, but I still have some doubts about the meaning of "inference engine" given by Romu) Romu, "inference engine", ça donnerait quoi en français ? Parce que si c'est moteur d'inférence, ça ne correspond pas à mes (vagues) souvenirs d'IA, dans le cas de la gestion de Sweet Home 3D ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 20, 2026, 7:41:49 AM |
