Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Some trees & stuff – sharing some of my larger exterior models. |
| Print at Jul 22, 2026, 6:10:43 AM | View all posts in this thread on one page |
| Posted by Ceciliabr at Jan 10, 2017, 10:25:12 AM |
Some trees & stuff – sharing some of my larger exterior models. At the request of OKH, I'm sharing some of the larger models from my 3D collection. Trees and bushes, a patch of grass, some plants, a nice grassy ground texture, a summer sky... and a few other items that you might find useful: Most of these are quite big models, although I have tried to reduce the size a bit. The SH3D-file containing the project is 227Mb uncompressed. Since most of my models are non-textured (by choice, because I often find it necessary to change the textures when using them in different projects anyway), I decided that the simplest way of sharing (for me) would be to present them in a project-file as textured models. My thoughts was that after downloading the project, one can decide which models to keep, export them as obj-files, and re-import the textured model. And then just delete the rest. Using a graphics editor (Gimp, Photoshop or other), it's easy to change the texture to reflect summer or autumn – or even winter, using transparency to remove the leaves. My preferred render settings for rendering exteriors: View full scale image Download project file Trees&stuff-ga.sh3d Grassy ground texture Jepp... Cec |
| Posted by Miker777 at Jan 10, 2017, 9:42:50 PM |
Re: Some trees & stuff – sharing some of my larger exterior models. Beautiful work Cec, count 1 as download ty Mike |
| Posted by bdfd at Jan 11, 2017, 6:31:34 AM |
Re: Some trees & stuff – sharing some of my larger exterior models. Fascinating reality for these pictures and models... Bravo Cecilia ! ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by VeroniQ at Jan 13, 2017, 7:40:15 PM |
Re: Some trees & stuff – sharing some of my larger exterior models. Thank you very much, Cecilia! Have you done these trees by yourself? Are they free to use? |
| Posted by Ceciliabr at Jan 14, 2017, 2:19:18 PM |
Re: Some trees & stuff – sharing some of my larger exterior models. @VeroniQ Yes, these are models and textures I have created using combinations of different designer software and my own photographs. The trees and the plants are created with Eon Vue and re-textured in Photoshop, rocks and grass are created with Poser Pro. The terrain is generated from a handcrafted heightfield map. The ground texture is created with various brushes in Photoshop, and is meant as an alternative to the tiled lawns. I have reduced the size to 1,4Mb. The resolution is 4096 x 4096, and it gives the best result if sized between 100 x 100 and 200 x 200 meters. You can of course use everything as you please. Cec |
| Posted by McCinski at Mar 4, 2018, 5:59:12 PM |
Re: Some trees & stuff – sharing some of my larger exterior models. Hi Cecil, Looked at most of your work, have to say its very impressive. as a relatively new user im just getting to grips with the sweethome and its rendering capabilities however had a few issues. i have a small question: in the top post with your lovely trees, you show the the photo renderer and the advanced settings, is this on an older version of sweethome? im currently running the latest but my "create photo" window doesnt show elapsed time, or remaining time and doest have external brightness setting either? just wondering if the new version looks different oh and thanks for the trees McC |
| Posted by Ceciliabr at Mar 5, 2018, 10:10:27 PM |
Re: Some trees & stuff – sharing some of my larger exterior models. Hi McCinski, Thanks for your kind words. You need Enko Nyito's fabulous plugin: https://sourceforge.net/p/sweethome3d/plug-in...otoVideoRendering-1.3.zip Or even better, get the resizeable version (Version 1.4.1), which you can find a link to in this post: http://sweethome3d.com/support/forum/viewthread_thread,7263_offset,20#38102 Cec |
Current timezone is GMT Jul 22, 2026, 6:10:43 AM |
