Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Walls |
| Print at Sep 20, 2026, 5:56:46 PM | |
| Posted by ITGreen at Nov 16, 2016, 11:34:23 PM |
Walls Please help... I am attempting to create a patio and the program keeps building walls around it. How do I prevent this? |
| Posted by okh at Nov 17, 2016, 8:36:12 AM |
Re: Walls This all depends on the patio really, whether it is just a paved area outside a building, whether it is raised (or the plan has levels), whether it has a roof/columns etc. And it is a bit odd that walls should be 'built by the program', if so, you could just delete them (or adjust the height of the walls? So maybe there is something here I miss. Anyway - assuming a simple patio in the form of a paved area outside: 1) Either just use the room tool to draw your patio on the ground, 2) or (especially if you have rounded parts) outline the patio with walls that connect around the surface, double-click with the room tool inside to create the 'room' (surface), and delete the walls (or just adjust their height down). ok |
| Posted by bdfd at Nov 17, 2016, 1:01:26 PM |
Re: Walls Please help... I am attempting to create a patio and the program keeps building walls around it. How do I prevent this? The better is 2 pictures.One of SH3D (bad result) and the second (example found on the web) that you want to realize... ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
Current timezone is GMT Sep 20, 2026, 5:56:46 PM |
