Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: heating, Water and air pipes |
| Print at Aug 22, 2026, 7:13:07 AM | |
| Posted by ersteinmal at Oct 27, 2016, 10:00:12 AM |
heating, Water and air pipes Dear all. Intro: I stoppend my searching at Sweet Home because the Drawing is very simple. But, my aim was, to sign pipes into my hause. Is there a Way? Regards Carsten |
| Posted by Davvey at Oct 27, 2016, 12:02:53 PM |
Re: heating, Water and air pipes Hi Yes there is a way to do pipes. I did it by making a small circular wall and then exporting it as a piece of furniture. Then re-importing this and scaling it. I also made a small rectangular set of walls and exported that as trunking. |
| Posted by Davvey at Oct 27, 2016, 12:07:01 PM |
Re: heating, Water and air pipes Sorry forgot to say also made right angle bends in both tube and trunking by using sloping walls to make half of a bend then imported it twice to get 2 halves. Then set them up as right angle bend and exported the 2 together to make bend. |
| Posted by VeroniQ at Oct 27, 2016, 9:24:53 PM |
Re: heating, Water and air pipes You can find some hot and cold tubes in the example 6 of the gallery |
| Posted by dorin at Oct 28, 2016, 3:47:24 PM |
Re: heating, Water and air pipes I use some furniture library for pipes or wire. This is the result: ![]() ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Aug 22, 2026, 7:13:07 AM |
