Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Length of a wall in the middle of a wall? |
| Print at Sep 30, 2026, 7:23:41 PM | View all posts in this thread on one page |
| Posted by Thomas_H at Oct 16, 2016, 11:12:24 PM |
Length of a wall in the middle of a wall?Hello, probably this is a noob question but I can't figure it out. In my case I try to create a room and then add the walls. The room has the length 276cm x 307,5 cm. But when I try to extend the walls the room shrinks. I see that the walls extends in both directions but I don't see an option to change this. Thanks in advance. Thomas |
| Posted by okh at Oct 17, 2016, 10:05:24 AM |
Re: Length of a wall in the middle of a wall? Assuming I understand... Walls are always determined from their middle point, so if you thicken a wall, it will grow in both directions.
| Posted by Thomas_H at Oct 17, 2016, 2:42:49 PM |
Re: Length of a wall in the middle of a wall? Hi okh, thank you for your explanation. I just thought I'm missing something. I can't understand this behavior. Nobody measures the distance inside a wall. |
| Posted by okh at Oct 17, 2016, 3:29:13 PM |
Re: Length of a wall in the middle of a wall? Nobody measures the distance inside a wall. That may be true. But a wall can be measured on the outside or on the inside and therefore have different lengths depending on different wall thicknesses. And which direction should an inner wall grow if thickness is increased? Cannot find the thread off-hand, but in the forum somewhere there is a discussion about this where Puybaret explains why. ok |
| Posted by Thomas_H at Oct 17, 2016, 4:35:02 PM |
Re: Length of a wall in the middle of a wall? I don't know if this is a seldom problem. I have the papers from my architect with exact measures from both sides inside and outside. That's why this measuring issue in the middle doesn't make sense to me. ;-) |
Current timezone is GMT Sep 30, 2026, 7:23:41 PM |
