Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to save 3D shape into furnture library |
| Print at Sep 30, 2026, 4:47:09 PM | |
| Posted by John37 at Sep 30, 2016, 1:19:06 AM |
How to save 3D shape into furnture library Is there a way to import a shape (box) made with the 3D Generator Tool into my furniture library so I can modify it to be a window/door? I want to use the 3D Generator to create a partially transparent box that I can then use to "punch" a hole in a wall. |
| Posted by bdfd at Sep 30, 2016, 8:39:59 AM |
Re: How to save 3D shape into furnture library Yeah, if I understand well. Import (furnitures, Import) <=> export (select object and right click on bottom right frame) ! ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by John37 at Sep 30, 2016, 10:41:31 AM |
Re: How to save 3D shape into furnture library Sorry, I don't understand your answer in relation to my question. I can create a transparent box in my plan using the 3D Shape Generator tool. But how can I get that object into my furniture catalogue (so I can change it into a window)? I know how to edit it once it is my furniture catalogue, but how to get it in there? |
| Posted by bdfd at Sep 30, 2016, 3:27:04 PM |
Re: How to save 3D shape into furnture library I'm OK with your creation. Two ways : 1. During import with 'furniture' -> 'import furniture' you can choose the catalog (and its name). 2. After creation, to modify it, double left clic on this object on the left upper frame (catalog icons) and a new box window appears... I hope to have been clear. ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by John37 at Sep 30, 2016, 6:18:26 PM |
Re: How to save 3D shape into furnture library Ok, maybe I'm not explaining the problem clearly. I'll try to make the question as simple as possible. How do I get an object from my plan into my furniture catalogue? 'furniture' -> 'import furniture' doesn't seem to do this - it won't import an object from the plan into the furniture catalogue. Try it: first select an object in a plan and then try to import it into the furniture catalogue. If you can do it, please let me know because that is what I need to do. |
| Posted by bdfd at Sep 30, 2016, 7:10:56 PM |
Re: How to save 3D shape into furnture library You want to see an existing object in the upper and lower right frames but absent from the category (even all)... Ok you create a Shape3D object. For this case, see my previous answer. Select it, export in OBJ and import it in good category. ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by okh at Sep 30, 2016, 7:15:12 PM |
Re: How to save 3D shape into furnture library Please, let me add to the confusion and suggest couple of steps:
Good luck - and good week-end. ok |
| Posted by John37 at Sep 30, 2016, 8:08:33 PM |
Re: How to save 3D shape into furnture library Thank you both for your rapid and helpful replies. It was the "Export selection as .obj (3d view - Export to OBJ format )" step that I was missing, I didn't know the function existed in the 3D view. Also, I guess I meant my standard catalogue, I didn't know how to refer to it. Anyway, problem solved, thanks again for your help. |
Current timezone is GMT Sep 30, 2026, 4:47:09 PM |
