Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: SH3D not rendering anymore |
| Print at Aug 15, 2026, 2:57:10 PM | |
| Posted by johnpolo at Sep 25, 2016, 5:04:12 PM |
SH3D not rendering anymore I have the following setup Mac OSX El Capitan Retina 5K 27 inch 4GHc I7 Intel 32GB Memory 4GB GPU I downloaded it from App Store a week ago. I designed 3 levels of a house from inside and out, including backyard. In the meanwhile, i added some models from your side, and tools as well, like export to HTML5, advanced rendering. All of a sudden, i cannot get any rendering result. Rendering window comes up and loading icon spins couple of times then, it tries to render then it leaves me with a dark picture with couple of empty squares. Tried, - Removing the tools - Maxing up the mem - Uninstalling the whole app and re-installing it - rendering simple designs No result. The same thing is happening. Its been only one week and my whole effort is gone after trying to design a model for my customer |
| Posted by Puybaret at Sep 25, 2016, 11:54:04 PM |
Re: SH3D not rendering anymore Maybe one of the models you imported has some problems to be rendered. Did you try at another point of view? Did you check if it bugs on a new home too? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by oooollels at Oct 1, 2016, 6:19:27 PM |
Re: SH3D not rendering anymore Hey I had the exact same problem. what i found was that the "virtual visitor" had set it's eye height to more than 3 meters.... It is a bit weird because i could still see everything in the 3d view. but it wouldn't catch much during rendering. anyhow i put it to 170 cm or so and it works again. maybe checking the settings of the "virtual visitor" in the 3d menu will solve your problem... |
Current timezone is GMT Aug 15, 2026, 2:57:10 PM |
