Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: How to create furniture with individually editable materials/textures/colors? |
| Print at Sep 30, 2026, 10:39:33 AM | View all posts in this thread on one page |
| Posted by MaMu at Sep 13, 2016, 12:25:29 PM |
How to create furniture with individually editable materials/textures/colors? I am able to create a new furniture via the "copy as new furniture" option and importing it afterwards. However, I can't seem to figure out how to make every part of it individually texturable (assign different material/color) like with e.g. the cylinder object where I can edit the top-, bottom- and cylinder-color individually. I tried it with grouping, but that didn't solve it. |
| Posted by okh at Sep 13, 2016, 1:00:07 PM |
Re: How to create furniture with individually editable materials/textures/colors? Which parts of a model can be assigned separate colours/textures, depends on the models. In other words, it needs to have surfaces with assigned names (like the cylinder). Also How a texture will stretch and tile on a surface can also be determined by the model itself. ok |
| Posted by MaMu at Sep 13, 2016, 1:24:44 PM |
Re: How to create furniture with individually editable materials/textures/colors? Would you mind to explain what you mean on an example to tell me "how to do it" which is what I asked for? |
| Posted by okh at Sep 13, 2016, 1:49:25 PM |
Re: How to create furniture with individually editable materials/textures/colors? I would if I could understand how you create your models. If I were to assume that you create furniture using walls etc in SH3D before you copy-as-new / export-import - you must assign colours/textures to the original walls before exporting-importing. If you do, the different colours/textures will be saved with the model, and show up as wall-1-1 etc in the modify furniture dialogue. Other pieces of furniture will retain their original surface names (like the cylinder). But I am making assumptions, and this may not be very helpful... ok |
| Posted by MaMu at Sep 13, 2016, 3:15:57 PM |
Re: How to create furniture with individually editable materials/textures/colors? Ah, I see. You assumed correctly. So far I misuse walls to create furniture and then copy as new furniture since I am not able to use 3D modeling tools like Blender, 3DS Max or Maya. I'll try what you suggested. |
Current timezone is GMT Sep 30, 2026, 10:39:33 AM |
