Print at Aug 19, 2026, 7:08:42 AM View all posts in this thread on one page
Posted by abhishka at Sep 9, 2016, 4:31:15 PM
Installation doesn't work. Software doesn't start.
I have purchased this product and when installed on my Mac only the start screen comes up but no other screen. Its the home loader screen which says the name of the software.
OS - OS X Yosemite
Processor - 2.5 Ghz Intel Core i7
Memory 16GB 1600 Mhz DDR3
Startup Disk - Machintosh HD
Graphics - AMD Radeon R9 M370x 2048 MB
Posted by Puybaret at Sep 12, 2016, 7:26:51 PM
Re: Installation doesn't work. Software doesn't start.
Really strange... This kind of problem may happen on other systems, but not on macOS sad
Would you be able to run Sweet Home 3D from a Terminal window to report here the messages it will say? Simply drag and drop Sweet Home 3D application in a Terminal window, type back space, copy-paste /Contents/MacOS/SweetHome3D and press enter.
You could try also the free version but it will require that you install Java 6 too.
Posted by martyt3 at Sep 22, 2016, 7:44:29 PM
It wont start for me either. Im on win 7
Posted by Puybaret at Oct 20, 2016, 2:01:57 PM
Martyt3, could you try version 5.3 beta 7?
Posted by jlecour at Nov 20, 2016, 4:03:07 PM
I have a similar issue. The program starts, I get the spashscreen, but it's frozen.
~ → /Users/jlecour/Desktop/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D
[JavaAppLauncher] Requested [1.5*], launching in [1.8] instead.
Java 3D: implicit antialiasing enabled
Exception in thread "J3D-Renderer-1" java.lang.UnsatisfiedLinkError: no jogl in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1867)
at java.lang.Runtime.loadLibrary0(Runtime.java:870)
at java.lang.System.loadLibrary(System.java:1122)
at com.sun.opengl.impl.NativeLibLoader.loadLibraryInternal(NativeLibLoader.java:189)
at com.sun.opengl.impl.NativeLibLoader.access$000(NativeLibLoader.java:49)
at com.sun.opengl.impl.NativeLibLoader$DefaultAction.loadLibrary(NativeLibLoader.java:80)
at com.sun.opengl.impl.NativeLibLoader.loadLibrary(NativeLibLoader.java:103)
at com.sun.opengl.impl.NativeLibLoader.access$200(NativeLibLoader.java:49)
at com.sun.opengl.impl.NativeLibLoader$1.run(NativeLibLoader.java:111)
at java.security.AccessController.doPrivileged(Native Method)
at com.sun.opengl.impl.NativeLibLoader.loadCore(NativeLibLoader.java:109)
at com.sun.opengl.impl.macosx.MacOSXGLDrawableFactory.<clinit>(MacOSXGLDrawableFactory.java:53)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at javax.media.opengl.GLDrawableFactory.getFactory(GLDrawableFactory.java:108)
at javax.media.j3d.JoglPipeline$QueryCanvas.<init>(JoglPipeline.java:9029)
at javax.media.j3d.JoglPipeline.getBestConfiguration(JoglPipeline.java:8793)
at javax.media.j3d.Renderer.doWork(Renderer.java:514)
at javax.media.j3d.J3dThread.run(J3dThread.java:275)
Posted by Puybaret at Nov 20, 2016, 4:24:28 PM
Jeremy, the first message of this thread talks about the Mac App Store version. Are you sure you're talking about that version or the free version? If it's the free version, would you have some jar files in the folder ~/Library/Java/Extensions if it exists? If it's the case, remove them, it should work better.
Posted by jlecour at Nov 20, 2016, 10:05:52 PM
Right, I'm using the free version. I didn't notice that aspect. Sorry.
Also, the "~/Library/Java/Extensions" doesn't exist (not even "~/Library/Java").
