Print at Aug 19, 2026, 11:43:56 AM View all posts in this thread on one page
Posted by Vcky at Sep 9, 2016, 2:43:04 PM
Which folder to Remove to delete the default furniture Library
Hello. i Like to use my own models in SH3D, so i used to delete the default library of models that came included with SH3D, to minimize clutter. I cant seem to find which folder or file to remove in the SH3D folder in program files in the latest version. Can anyone help me? smile
Posted by Puybaret at Sep 12, 2016, 7:11:49 PM
Re: Which folder to Remove to delete the default furniture Library
You should remove the file Furniture.jar found in a sub folder of the installation folder of Sweet Home 3D.
Posted by santbose at Sep 13, 2016, 7:51:35 AM
Can I remove selective models from this file?
Posted by HawkDawg at Sep 19, 2016, 1:23:38 PM
You can open jar files using 7-Zip .
Hawk
Posted by Puybaret at Oct 19, 2016, 5:23:32 PM
It will be tedious: if you remove some models or images, you should remove the matching piece of furniture from the DefaultFurnitureCatalog.properties and/or ContributedFurnitureCatalog.properties files (+ translation files you use if you don't run the program in English), and then update the numeric order of the pieces following the removed one, to ensure there's no missing number between two numbers (piece #1 must be followed by piece #2, then by piece #3...).
An easier way is to reorganize the Furniture.jar file as two .sh3f files by copying its com folder and the content of the DefaultFurnitureCatalog.properties file (then ContributedFurnitureCatalog.properties file for the second .sh3f file) in the PluginFurnitureCatalog.properties file of an empty new .sh3f file. Then you should be able to edit these files with the Furniture Library Editor. Unused 3D models and icons will be removed at saving time.
