Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: SweetHome3D On Surface Book Hi Res Display |
| Print at Aug 20, 2026, 5:28:42 AM |
| Posted by Slate at Oct 3, 2017, 6:19:28 PM |
Re: SweetHome3D On Surface Book Hi Res Display Hello I also have a Microsoft Surface Book with 3000x2000 display and I'm not having any luck getting the display to look decent. It seems no matter what I try I still have a truncated left menu in Sweet Home 3D. I've tried both the Windows 5.5.2 version and adding an ini file with 1 line or the 5 lines of code mentioned here to no avail, and the Java Web Start 5.5.2 version. Any thoughts? |
| Posted by Puybaret at Oct 3, 2017, 9:53:08 PM |
Re: SweetHome3D On Surface Book Hi Res Display Are you sure the .ini file doesn't have an additional .txt extension? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Slate at Oct 6, 2017, 4:26:29 AM |
Re: SweetHome3D On Surface Book Hi Res Display Arg you're absolutely right, I recently switched computers and I didn't realize the option to view file extensions was still turned off so the file was actually showing .ini.txt instead of just .ini. Many thanks for your spot-on reply! |
| Posted by Puybaret at Oct 6, 2017, 6:01:25 AM |
Re: SweetHome3D On Surface Book Hi Res Display Thanks for your feedback I feared that the solution I programmed didn't work anymore on some configurations... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 20, 2026, 5:28:42 AM |
