Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Put on board 30 cm high walls |
| Print at Oct 6, 2026, 6:55:02 AM | |
| Posted by MarkusSB at Aug 22, 2016, 10:28:53 PM |
Put on board 30 cm high walls Hello, I want to create a sketch in which I I make 3 30 cm high walls (Ytong) and on a "wooden plate" Place. Can anyone give a tip, have nothing corresponding Found. greeting Markus With google-translator of German translated to English |
| Posted by Miker777 at Aug 22, 2016, 11:53:21 PM |
Re: Put on board 30 cm high walls I think i understand, you want a texture to appear as Ytong blocks, if that is so, i believe you can take a photo, resize it in "paint" or "photoshop" and then import it to sh3d as a texture. I think!!! Mike |
| Posted by okh at Aug 22, 2016, 11:59:40 PM |
Re: Put on board 30 cm high walls Hi Markus, sorry, I read your German and English question, but I have a problem figuring out what your problem is. The walls are easy to make, just change them to 330 cm high. Then, you could make a new level 330cm above the first level and use a box (or several boxes) and add wood texture. But I suspect I may not have understood what you are trying to do... Some more information (in German or English) and it might give you more replies. ok |
Current timezone is GMT Oct 6, 2026, 6:55:02 AM |
