Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: setting new walls.. |
| Print at Sep 6, 2026, 5:11:13 AM | View all posts in this thread on one page |
| Posted by lalberts at Aug 21, 2016, 1:39:21 PM |
setting new walls.. I would wish a constantly open window where you change your wall thickness as you set your wall.. set, then modify attributes, click ok, set a new (not appropriate) wall, reopen the attributes window, redefine thickness, click ok,.. this is not really fast.. Having this attribute window open all-time and of course changing the walls as you type the values, this would speed up this first step of reading in plans.. newbie, still in phase1, reading in plans. thanks Lukas |
| Posted by danger89 at Nov 1, 2016, 11:52:18 PM |
Re: setting new walls.. uh yea agreed! After creeating 4 houses and 140 walls later it's a hell. We need a feature to update several items as once, with similar objects likes multi selection of walls in this case. |
| Posted by Puybaret at Nov 2, 2016, 12:51:49 AM |
Re: setting new walls.. If you want to change the thickness of more than a wall at the same time, select them and choose the Plan > Modify walls menu item. You may even choose this menu item if the selection contains something else! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 5:11:13 AM |
