Print at Jul 22, 2026, 3:28:34 PM
Posted by David251 at Aug 7, 2016, 5:22:28 PM
sad   Origin and scale of measurements?
I love this tool, but I used it wrong. I started entering my wall measurements at 42 feet from the left, so they are too crowded and too far from the left.
I've searched the Help and the Forum and I can't find any way to move the whole plan to the left or to change the origin of the measurement system. Also, I need to change the scale (permanent zoom) so the room I am modelling is shown larger on my screen.
Can someone help?
Posted by bdfd at Aug 8, 2016, 7:24:14 PM
Re: Origin and scale of measurements?
Sorry but I tried few tests and I don't understand...
Can you send us a picture with annotations please ?
Posted by David251 at Aug 8, 2016, 8:01:38 PM
smile   Re: Origin and scale of measurements?
Thank you, but I needed to get it working for me yesterday. I simply started over again, copying all the walls from the first try.
I then pasted the walls so they started at offset 0,0. It worked great from there.
Almost everything about this program worked once I figured it out, and it was very easy to model our living room and its furniture. I downloaded and imported two pieces of furniture when the range of builtin furniture was not sufficient. I'm very pleased and plan to make a small financial donation when our project is done.
I have started recommending Sweet Home to others. I love using Sweet Home 3D!
The only feature that doesn't work well is the lighting. The 3D view doesn't show any lighting effects, and the "photo" rendering makes the shadows too sharp, which makes the view too full of glare. Also, the rendering is very slow (the tradeoff between rendering speed and lighting effects is not good). The lighting is much better in at least one of your competitors (blophome.com).
Also, the 3D view is off-center, with no way to center it.
My recommendation to the developer is to ship the product with several examples, a simple one with one room, walls, and a few pieces of furniture, and a complex and realistic one with several rooms. When the user first opens Sweet Home, it should already show the simple example, so that users can use it and modify it as a starting point, to get familiar with it. The Help pages are not good enough.
Posted by bdfd at Aug 9, 2016, 7:32:23 AM
I understand better this time. smile
Experience comes with practice.
Good reports are long, go visit the gallery and see some nice pictures ...
The time calculations are sometimes a bit long but worth it.
For not be disappointed you have to use the plugin rendering 1.3.1
Good modeling.
