Print at Sep 27, 2026, 9:25:32 PM View all posts in this thread on one page
Posted by jimosity at Jul 13, 2016, 5:35:11 PM
Rename furniture?
Is it possible to rename furniture?
It's difficult to find items and if I could rename them; it would make my life easier.
Looking for 'cabinets' and having them under 'lower cabinet' or 'grey cabinet' doesn't put all of them together - I'd like to organize better. Such as 'CABINET - lower', 'CABINET - grey', etc.
Posted by okh at Jul 14, 2016, 9:26:38 AM
Re: Rename furniture?
For items in your plan (lower left pane), you can change names at will (also several at the same time). Select item(s) and change name. As for the catalogue(s) - upper left pane, the easiest is usually to switch between the two different display options (Preferences, Furniture catalog view): categories / search.
You can also use the Furniture Library Editor to change properties to installed libraries/collections. Typically this is used for personal furniture collections.
Posted by lama1980 at Jul 15, 2016, 10:14:12 AM
Sure, you can do it.
