Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Rogue item in aerial view |
| Print at Jul 31, 2026, 3:18:33 AM | View all posts in this thread on one page |
| Posted by Stopgap at Jun 13, 2016, 2:36:15 AM |
Rogue item in aerial view My aerial view appears to contain a "rogue" item that does not appear on my plan. The item is some distance from the main plan and consequently causes the aerial view to be "zoomed out". The item appears on the left of the aerial view, so zooming out on the plan doesn't reveal it, as this only shows white space below and to the right. I've also tried cutting and pasting everything, but that hasn't helped. Has anyone had a similar experience and found a way to resolve it? Thanks for any help. |
| Posted by Puybaret at Jun 13, 2016, 2:33:13 PM |
Re: Rogue item in aerial view Choose Edit > Select all menu item and zoom out in the plan. This should help you to find where this item is placed in the plan and delete it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Stopgap at Jun 14, 2016, 2:03:28 AM |
Re: Rogue item in aerial view No, that doesn't help. The item doesn't seem to get picked up in the plan - only the aerial view. I can send a screen dump if that helps? Not sure how to upload them here. |
| Posted by HawkDawg at Jun 15, 2016, 4:19:31 PM |
Re: Rogue item in aerial view I can send a screen dump if that helps? Not sure how to upload them here. Maybe this topic will help. http://www.sweethome3d.com/support/forum/viewthread_thread,1886 ---------------------------------------- Hawk |
| Posted by Stopgap at Jun 16, 2016, 12:18:34 AM |
Re: Rogue item in aerial view I have resolved it - thanks for you help. I gradually copied and pasted sections of the plan into a new plan until the issue re-appeared, and then back tracked until it didn't. It turned out to be an item (a microwave actually) on the plan, but it showed up separate in the aerial view, which caused it to be zoomed out. Thanks again. |
Current timezone is GMT Jul 31, 2026, 3:18:33 AM |
