Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Elevation Problem |
| Print at Sep 10, 2026, 6:22:18 AM | |
| Posted by tinboye at Apr 30, 2016, 8:36:18 PM |
Elevation Problem I have a drawing with 3 different levels. basically my basement, then you come up the stairs, and there is a little landing to go into the backyard, then there is another set of stairs 18" high(3 steps) then the main floor. So in the software(latest version) I have https://gyazo.com/6467f00ad1d08eb1dbb55495ea459527 for my elevation settings. this is what it looks like: https://gyazo.com/bc0e870a591003d5b882b6bb21506fa8 the dark grey is the section that should be 1'6" where the white section should be 8' tall. anyone see why this is rendering this way? |
| Posted by Puybaret at May 6, 2016, 7:31:42 PM |
Re: Elevation Problem When you get this kind of mixed colors on walls, it generally means that there are some superimposed walls at that place. You should probably try to adjust the height of your walls. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 10, 2026, 6:22:18 AM |
