Print at Sep 15, 2026, 8:04:21 AM View all posts in this thread on one page
Posted by rayclout at Apr 21, 2016, 2:59:49 AM
color change for doors
It would be nice to be able to change the color of either side of windows or doors.
For example....its very common for a door between a bedroom and living space be color matched to the room, which in my experience can be different paint colors.....same goes for window frames with an outside and inside surface....different colors
Posted by santbose at Apr 21, 2016, 7:56:27 AM
Re: color change for doors
Rayclout, you can right click on the door and in the dialogue box which pops up, click on modify, which will show the colours of the door or window. then you can change the colours from there.
Posted by rayclout at Apr 22, 2016, 3:56:32 AM
I meant...change door color sides "independent" of each other, as can be done for walls
If I have a bedroom door leading into a living space, I paint the door panel same color as room color.....which can and mostly are different color
I can't see how this is done with the modify menu
Posted by okh at Apr 22, 2016, 9:43:40 AM
Whether you can change sides / elements individually, depends on the door model you use. This door can have different colours on different elements (from a post about separating door and frame, SF 3D models 334.
Cannot remember off-hand which SH3D library doors have separately named elements, so you will have to experiment. Good luck. ok
Posted by kaleem at Apr 22, 2016, 2:28:59 PM
Yes Both side colous should different because now a days it is trend all walls should different color, doors color should different and window color also different. So you can paint both side with different color.
