Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: problem render become gray |
| Print at Sep 20, 2026, 9:49:29 AM | |
| Posted by fhoofman at Apr 10, 2016, 12:41:29 PM |
problem render become gray I have a problem while rendering photo. here's the result. any suggestion? ![]() http://www.mediafire.com/view/x3mpst8f5v95ihy/BDS2.png |
| Posted by hansmex at Apr 10, 2016, 1:30:45 PM |
Re: problem render become gray Looks normal enough to me. When rendering in Q3 or Q4, the result should resemble a real-life colour representation. Surfaces with the same colour, will appear different due to the amount, angle and colour of light they catch, and the way they reflect it due to surface and shininess. If you want an even white colour, use the lower settings Q1 and Q2. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by fhoofman at Apr 10, 2016, 2:45:24 PM |
Re: problem render become gray Please have a look at the woman's head. Her head showed the wrong color |
| Posted by hansmex at Apr 10, 2016, 3:48:07 PM |
Re: problem render become gray To minimize this effect you may try the following: - change the shininess of the model - Modify furniture - Shininess - Matt - change to lower quality setting Q3. if you need high resolution, make the image 1000x1000 pixels, then reduce to 500x500 pixels. ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 20, 2026, 9:49:29 AM |
