Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: 3D error WIN10 |
| Print at Oct 2, 2026, 1:30:16 AM | |
| Posted by hansveldt at Mar 6, 2016, 6:19:00 PM |
3D error WIN10 Installed sweethome3d 5.2 on WIN10. Installation seems ok. After starting, the program shows up but an error "3D error" (or 3D fout in Dutch) appears. |
| Posted by Albino6 at Mar 7, 2016, 8:38:14 AM |
Re: 3D error WIN10 I have the same problem. I started the program with Java webstart. Win 7 64 bit Intel Xeon Is there also a portable version of 5.2 |
| Posted by Rudie at Apr 5, 2016, 10:56:22 PM |
Re: 3D error WIN10 Sama problem here Also in the Dutch version.... |
| Posted by deberkjes at Apr 19, 2016, 10:46:56 AM |
Re: 3D error WIN10 Also I have the same problem. version 5.2 Installation went well but received the note that my DirectX is not the right version. Have Windows 10 and Dirext X 11.1. Have tried Windows update but they gave the message all is at the latest versions. Please advice what to do. Version 5.0 on an computer works well. |
| Posted by Puybaret at May 20, 2016, 8:53:35 PM |
Re: 3D error WIN10 Please try the version 5.3 Beta 6 which should fix this issue. As this Beta version doesn't contain any new feature yet, you can continue to use it without risk until the final version 5.3. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by leon42 at Aug 29, 2016, 9:09:15 PM |
Re: 3D error WIN10 Very Strange problem ! I installed SH3D on my surface4 , it works perfectly for a couple of time , execpt tiny icons and menus . I found the solution in the threads But before having tried this solutions SH3D doesn't start anymore ? I tried the 5.3 java web start . SH3D starts and stops (direct X Problems ) I'm very disappointed , I need to use and old computer to be able to launch SH3D A tablet or surface is very useful to have your drawing anywhere on the workshop Thanks in advance for your help |
| Posted by leon42 at Aug 31, 2016, 6:37:01 AM |
Re: 3D error WIN10 I finally found the solution It is due to the windows update The latest version probably a beta one of windows has been installed . I reinstall the win 10 previous version and right now SH3D works perfectly on my surface 4 with the 5.3 beta and HiDPI parameter Greattttttttttttttttttt ! |
Current timezone is GMT Oct 2, 2026, 1:30:16 AM |
